Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Burnout/Launch Help
Old Jun 26, 2017 | 09:07 AM
ksurfer2's Avatar
ksurfer2
Default Burnout/Launch Help
My car is a 12 gs M6 with headers, cam, ecs1500 blower, meth, and an RPS twin disc clutch. I make 671rwhp. At the track, I run stock sized front wheels/tires. On the rear I run a 345/35/18 Mickey Thompson ET Street. To date, my personal best is an 11.03 @ 127.
I am doing burnouts in 1st gear. However, the back end will always start to slide sideways to the point that I feel it is becoming unsafe and I stop the burnout. I have yet to be able to make significant white smoke and don't think I am getting the tires warm enough.
My best 60' time to date is a 1.8. Any efforts to launch any harder inevitably end up in excessive tire spin. Any tips will be greatly appreciated. I really want that 10.XX time slip!!!!!
Old Jun 26, 2017 | 09:19 AM
76Rat's Avatar
76Rat
Do your burnouts in second gear to heat them up more. How much air are you running in the tires?
Old Jun 26, 2017 | 09:26 AM
ksurfer2's Avatar
ksurfer2
Typically run about 22psi. I'll try second gear. Will that help keep the rear from sneaking off to the side?
Old Jun 26, 2017 | 03:05 PM
TX Z06 02's Avatar
TX Z06 02
Do you have a line lock, or just dumping the clutch for the burnout?
Line lock should help you from going sideways...
Old Jun 26, 2017 | 03:22 PM
ksurfer2's Avatar
ksurfer2
Just dumping clutch.
76Rat's Avatar
76Rat
Without the line lock you cant spin them long enough to get them hot enough. Hopefully you have one.
Old Jun 26, 2017 | 03:57 PM
TX Z06 02's Avatar
TX Z06 02
If you're gonna be spending some time at the track, definitely need a line lock. Like Rat said...you're not getting tires hot enough without one.
Old Jun 27, 2017 | 08:22 AM
pocketrocket's Avatar
pocketrocket
You may want to call M/T and speak with the tire tech. They will advise you on the proper tire psi and to data log your results. They are very helpful.
Old Jun 29, 2017 | 03:05 PM
robz's Avatar
robz
Without a line lock most people don't keep the revs up high enough or get on the brakes "lightly" quick enough. You need that initial hit to get those tires moving.
So, when the rear wants to kick out it's usually because you need more rpm and wheel speed to avoid one or both tires trying to grip assuming you are on a nice level area.
Also, make sure you are on a level patch without one tire partially in the groove and the other on the incline of the groove.
Another trick is to stop at the leading edge of the water box where the pavement is damp to allow for the tires to light right up. You will often have to keep feeding it throttle to maintain the rpms. Often giving it more throttle will straighten the car out but not always.
It takes a little practice and safety comes first, so if the rear gets too far out hit the brakes and bail on the burnout.
I'd start the drag radials @ 18psi cold.
Be aggressive with the burnout but cautious as well and always be willing to abort and start over.
Your tires need to be hot to 60' the car.
A second gear burnout may be a good solution but will often require the initial rpms to be higher than in first.
Old Sep 22, 2017 | 01:16 AM
hawk93's Avatar
hawk93
Default Psi
I have the same tires and I tried everything... I found 17-17.5 to be the best. I can hook with 1.5 60ft
Old Sep 23, 2017 | 07:32 PM
davered00ss's Avatar
davered00ss
Drop to 18 psi and get a line lock
Old Oct 1, 2017 | 06:13 PM
jimbob8915's Avatar
jimbob8915
What is a good line lock that does not interfere with the computer? Are there any that come with lines already made an just bolt in?
Old Oct 1, 2017 | 10:01 PM
TX Z06 02's Avatar
TX Z06 02
Try fastbird performance.
Old Oct 2, 2017 | 07:32 AM
davered00ss
RDS Line lock. do a search for it.
To Burnout/Launch Help
