Hoosier DR2
Aug 5, 2018 | 06:28 PM
Hoosier DR2
I'm told the DR2 has a softer side wall compared to a ET street SS and will wrinkle
Any one run these tires?
Aug 6, 2018 | 01:37 PM
2024 C6 of the Year Finalist - Modified
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Quote:
Originally Posted by
kirk tarrant
I do, and yes they do wrinkle.
Aug 7, 2018 | 12:27 PM
I run them also. Lightest drag radial you can get and plenty of wrinkle!
Aug 7, 2018 | 04:12 PM
Is that a stick car with wheels up?
blkscls1z
Aug 8, 2018 | 01:51 PM
Aug 8, 2018 | 02:42 PM
blkscls1z
It's an auto
Mine too.
Aug 8, 2018 | 04:54 PM
ahhhh. I just did a auto swap in c6 for a friend. my car is a stick but my et streets ss are breaking too many parts
Aug 15, 2018 | 08:32 PM
same thing I use. They work well
Aug 16, 2018 | 10:10 AM
kirk tarrant
Switch to a bias ply tire...MT Et drag stiff wall
Oct 30, 2018 | 03:53 PM
subfloor@centurytrans
Awesome! Can you tell me what size your using?
Oct 30, 2018 | 03:59 PM
blkscls1z
Awesome can you tell me what size are you using!
Oct 30, 2018 | 04:35 PM
avtarv
awesome! Can you tell me what size your using?
315/35/17
Nov 14, 2018 | 01:05 PM
what PSI are you guys liking?
Nov 14, 2018 | 01:07 PM
2MCHPWR
18.5 psi, measured before each and every pass. Some people apparently will only measure it once when they get to the track which makes no sense to me whatsoever.
Nov 17, 2018 | 07:03 AM
kirk tarrant
You should not think that switching to the Hoosier will not cause any parts breakage in your stick car.
The 315 Hoosier is a great tire but is very aggressive.
95vettski
The Hoosier QTP is another good choice as well as MT ET Street bias ply and the M&H Cheater slick.
Not that any tire can prevent breakage; however, these tires significantly reduce the chances.
Driving style, track prep and clutch play a significant role also.
