Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
How do you Drag Race??
Old Oct 29, 2002 | 01:27 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Default How do you Drag Race??
[Modified by Mr. Magoo, 7:44 AM 11/6/2002]
Old Oct 29, 2002 | 02:01 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Re: How do you Drag Race?? (Mr. Magoo)
Loading the coverter (bumping up to 1600) is a good idea if you have the tires to take it. On street tires, it will be too much and thus your spin. Loading it might not be right for your setup at least not that much.
You seem to be getting a fairly good 60' time but your ET and MPH seem low. I would expect to see your MPH in the 99 range.
Maybe someone with an 86 can chime in there are some very good ones here.
It is possible that weather was holding you back some.
Old Oct 29, 2002 | 02:34 PM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: How do you Drag Race?? (REDGAR)
According to a lot of the locals the track conditions were pretty good. It was about 50 degrees out and we were about 450 above sea level with a slight breeze.
Old Oct 29, 2002 | 02:35 PM
MI_SS_IL's Avatar
MI_SS_IL
1.9 60's on street tires? :eek: Damn, freaking automatics :mad Those are some great numbers ... and you're asking for advice? About all you can do is bring the rpms up and see if you get any spin. Awesome launch!
Chris
Old Oct 29, 2002 | 02:38 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Those are fair weather conditions. Again I need someone with a similar car to chime in but I feel that there might be a problem at the top end.
I once found that I was launching well but was not getting the ET and MPH and the cause was the that the throttle cable was not fully adjusted. I put the peddle to the floor the by the butterfly opened only 1/2 to 3/4 way. After adjusting the cable the ET and MPH came back. Not saying you have this problem just that it may not be you at all the reason for the 96 MPH
Old Oct 29, 2002 | 02:39 PM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: (MI_SS_IL)
Chris
[Modified by Mr. Magoo, 7:45 AM 11/6/2002]
Old Oct 29, 2002 | 02:42 PM
Mr. Magoo's Avatar
Mr. Magoo
Thanks Redgar I'll look at this when I get home from work. :cool:
Old Oct 29, 2002 | 02:51 PM
Guest
Guest
Posts: n/a
Magoo, the offer is still there if you want to come by and bolt on the NIttos.....gaurntee youll run a 13 then :D
Old Oct 29, 2002 | 06:27 PM
rcolling's Avatar
rcolling
Leaving at idle with my auto '86 is how I got my best times. Whenever I tried preloading I spun badly. Those 60's are good on street tires.
My best was 1.92 60', 14.1, 95mph
Old Oct 29, 2002 | 06:37 PM
Mr. Magoo's Avatar
Mr. Magoo
Redgar I checked my TB Butterflies and sure enough there are not opening all the way, if fact they are only opening about ½ inch! :eek:
When I had a friend stand on the gas pedal I could still move the TB lever about 3/4 of an inch for it to be wide open (Butterflies horizontal).
I guess this could be one of my problems. :crazy:
Old Oct 29, 2002 | 07:00 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
magoo, plain and simple.... you suck :p:
honestly, if you preload the convertor to 1500rpms then when the 3rd yellow comes on, let off the brake and dont get into the throttle, once you get rolling, then punch it.
i tried telling you this, but you mashed it from 1600 and went up in smoke :seeya
Old Oct 29, 2002 | 10:33 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
:eek:
Old Oct 30, 2002 | 12:25 PM
MI_SS_IL's Avatar
MI_SS_IL
Default Re: (Mr. Magoo)
Yes a great 60' but that's it........then it just runs out of breath. Dog city!! :rolleyes:
There are 2 ways to lower your e.t.. You can either get a better launch (chances are you aren't going to improve it that much if at all ... it's pretty damn good right now) or you have to get more power out of the car. Getting power out of the car without modding will be tricky.
Little things that will affect your mph (trap speed).
1. temperature ... the cooler the better, make sure you run on a cool engine, ice it if you have to
2. stupid little things like making sure the filter is clean or that the car isn't carboned up
3. the throttle body thing the guy above mentioned ... on my car I had the same problem (it's a common factory restriction on LS1 Fbodies). I had to shave the throttle body stop down with a dremel tool so that my throttle blade would open all the way.
4. raising the tire pressure in the front might give you a little mph
5. when you stage, just barely trip the second light ... theoretically you get a very, very slight rolling start this way ... as opposed to staging too close to the starting (e.t.) line.
6. weight reduction
My advice though is just to try and get a better launch if you can. You only have to improve it very slightly to crack a 13.
Good luck
Chris
Old Oct 31, 2002 | 04:11 AM
Nitro Junkie's Avatar
Nitro Junkie
I run high 1.8 - low 1.9 60' on stock Goodyears (P255-50/ZR16). I do a short burnout to heat the tires, stage shallow (to get a running start), flash the stock convertor to 2000 RPM with the brake on, and leave on the last yellow.
When I first started racing, I would leave from idle, and just mash the loud pedal. 60' were 2.1 - 2.2. I always run in D (3rd) and let the tranny shift itself.
See my sig for my best time. Not too shabby for a "Catch Fire"
Old Oct 31, 2002 | 04:08 PM
TLewis4095's Avatar
TLewis4095
Chris
We ran a best 60' last fall of 1.878 with stock tranny & TC as well as bald run-flats!!! Usual is 1.91-1.96 though with SO2's or BFG DR's. :cheers:
Old Oct 31, 2002 | 04:26 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Magoo I bet you'll find that was the problem then. Grab a manual and adjust it and you should be golden.
Wow, can you all believe I successfully diagnosed one :eek:
Old Oct 31, 2002 | 07:33 PM
KyleBst264's Avatar
KyleBst264
Mark, when you're staged load the converter up to about 1,200-1,500 RPM. When the last yellow goes on release the brake, and gradually roll onto the throttle, once the car feels like it's moving to quick to spin the tires nail the throttle down the rest of the way. It's really tough to explain this, but it's all about "feel" and finding exactly how to do it for your car.
To How do you Drag Race??
Old Nov 1, 2002 | 08:57 AM
Mr. Magoo's Avatar
Mr. Magoo
Yes you did diagnose the problem correct Redgar. :cheers:
It my own damn fault really, when I bought this Vette the silly azz that owned it before me had a NOS plate just before the Throttle Body. I removed it when I changed my old intake to a Ported AS&M intake and never replaced the bracket that the Throttle cable and TV cable hook up to. I have a ton of slack in the throttle cable, thus the reason for my butterflies not opening. D'OH!!! I was only running at half throttle down the track last Sunday and never went into WOT. :rolleyes: Well at least it's an easy fix, too bad the seasons over though. :(
Old Nov 1, 2002 | 09:10 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
The season is not over. We have a Corvette Challenge tomorrow and again on nov 9th so saddle up and come down to E-Town.
Old Nov 1, 2002 | 10:11 AM
MI_SS_IL's Avatar
MI_SS_IL
Default Re: (TLewis4095)
On runflats? You guys make me sick. One day I'm going to come down there just to see what it's like to run on a track that actually throws some VHT down. I've only been to one well prepped track before and I bogged all day because I was so used to the regular no-prep tracks I go to.
1.8's :mad 1 day I'm going to hit that (then I'll probably miss a shift :p: )
Chris
