Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
longer wheel studs
Old Nov 3, 2002 | 10:01 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default longer wheel studs
when i went to the track today one of the officials came running over informing me and a lot of other guys well have to go to long wheel studs on the front and back they said something about some new rules :mad
Old Nov 3, 2002 | 10:23 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: longer wheel studs (CORKVETTE1)
The rule unless they just changed it was that the stud must protrude into thr hex portion of the stud be the length of the dia.
Old Nov 3, 2002 | 10:27 PM
scorp508's Avatar
scorp508
If your studs are for example 1/2" wide then they must go into the hexagonal portion of the lugnut that far (so 1/2" past the tapered part). Get the long ones so that they stick out past the nuts and they won't have issues with ya.
Old Nov 4, 2002 | 01:09 AM
hookedup's Avatar
hookedup
Default Re: (scorp508)
Has anyone found studs that are long enough to do that with Weld's & 5/16 spacers? The Moroso's aren't long enough! :nonod:
Dave
Old Nov 4, 2002 | 03:09 PM
ROK 64's Avatar
ROK 64
Default Re: (new92racer)
What's involved in changing the studs and where do I buy them. I'm getting ready to install Pro Stars on my '84.
Old Nov 4, 2002 | 06:48 PM
mackeyred96
Dave
You are correct.
It's to close to call.
Old Nov 5, 2002 | 01:03 AM
pablocruise's Avatar
pablocruise
Dave
the ARP's aren't long enough either(shhh.........don't tell the tech inspectors around here) but they're working for me with the long shank nuts.
Old Nov 5, 2002 | 07:18 PM
hookedup's Avatar
hookedup
Default Re: (89 Paul in Cal)
Hey Paul,
They're working for me to, but don't tell anybody, they're still not long enough! The only other thing to do would be try finding a stud with the same diameter knurl in SAE thread and use non-metric lug nuts.
Dave
Old Nov 6, 2002 | 12:23 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Corkvette1,
Do you know when this new requiremnt kicks in. ie:minimum time like 12's.
Just curious - are you still redoing your motor? Just wondering time frame on heads.
Where were you this weekend? I thought the tracks were closed for the season.
Jim
Old Nov 6, 2002 | 12:45 AM
scorp508's Avatar
scorp508
Guys,
There were differnt length lugnuts used over the years of C4s. I don't know what years had the shorter ones, but it might get you by.
Old Nov 6, 2002 | 07:22 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: longer wheel studs (85vet)
the track guy told me they are going to enforce it starting next year. keystone and dragway 42 is still opened for a couple more weeks i am going back to keystone this sunday again as long as the weather holds out stil trying for that 10 sec et :cheers:
[Modified by CORKVETTE1, 8:03 PM 11/6/2002]
Old Nov 6, 2002 | 06:35 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
The weather looks pretty good cork. I will be down to watch. I'd like to race but I would need a team of guys to push me around. :D
Talk to you on Friday! :cheers:
Old Nov 6, 2002 | 09:04 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Default Re: longer wheel studs (ski_dwn_it)
bring the old mans car down :cheers:
Old Nov 6, 2002 | 10:14 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Corkvette1,
How busy is it on Sunday?
I might come out for a couple hours. I was going to start tearing down the engine - But it can wait!!!
I see the gates open at 9 and racing at 11. What time do you normally get there?
Jim
Old Nov 6, 2002 | 10:33 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
85 i try and get there at 10 the last 2 weeks its been dead there but 3 weeks ago it was smashed so who knows :cheers:
Old Nov 6, 2002 | 11:43 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I am definately planning to show :cheers:
Jim
Old Nov 13, 2002 | 12:34 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
I use longer studs that work on my 93 with Weld Pro Stars. I use a factory GM part number, They are easy to install. I can get the number. they are about 3 1/2 inches long?? I got them from a friend here in Oahu, who I bought the wheels and tires from. I just raced this weekend and passed tech, well at least in hawaii, and they did look at the studs.
ps, I have H&R spacers for the rear. Trust me, these studs fit and they come to the end of the wheel lugs on the welds front and rear.
[Modified by steve40th, 7:36 PM 11/12/2002]
Old Nov 19, 2002 | 02:19 PM
Arnie's Avatar
Arnie
Cruise-In II Veteran
Default Re: longer wheel studs (steve40th)
Can you post the part # when you get a chance.
On doug Rippie's web site they show race lug studs that are 1" longer than stock, what are the stock lengths?
Thanks in advance...
To longer wheel studs
