Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Gears with supercharger?
Old Nov 1, 2019 | 08:11 AM
m60gov20's Avatar
m60gov20
Default Gears with supercharger?
I'm having RPm Transmission install a Monster LT1-S twin disc. So if I'm going to do a gear nows the time. With Eforce, 3.5" pulley it made 528whp and 477wtq. I have since added 1 7/8" ARH headers and a Tick master cylinder. I have a set of ID1000 3.25" pulley to install. It feels like the headers helped a good bit. As far as future mods, I'm considering meth or my tuner is recommending e85, possibly a 3" pulley. I'm going to do a larger resivour for the heat exchanger too. I'm thinking I'll end up somewhere between 600-700 whp depending on what all I do. Would a 4.10 be too much gear? Should I be looking at a 3.73? I'm running 19" nto5r's not bit thinking about a set of et street r's on 17's.
Old Nov 1, 2019 | 09:28 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
This type of power added has plenty of tq to pull you out with 3.42 gear. IMHO, you will really struggle with traction if you to with anything lower (higher numerically) then 3.42.
Old Nov 2, 2019 | 01:20 PM
m60gov20's Avatar
m60gov20
Would less power and more gear be easier to launch and get similar results?
Old Nov 2, 2019 | 09:10 PM
383vett's Avatar
383vett
What car do you have? Are you setting up for street, 1/8 mile, 1/4 mile, 1/2 mile, top speed?
Old Nov 2, 2019 | 09:18 PM
m60gov20's Avatar
m60gov20
Its a 2008 base with z51 option. I drive it quit a bit in the summertime. I dont ever see me doing a 1/2 mile. I will mostly run the 1/8th because it's only 15 minutes from my house but will do some 1/4 mile also.
To Gears with supercharger?
