Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
A4 Dragging Technique
Old Dec 3, 2002 | 05:18 PM
C5Sweden's Avatar
C5Sweden
Default A4 Dragging Technique
Hello again guys
So far when I have been dragging I have driven in "D- mode" with the A4 and managed to do 13.13 with only open air filter and exhaust.
Now I have installed a 150 shot wet NX-system, cant use "D-mode" then, the gearbox shifts when lifting off BUT how the hell do you guys get good shifts when just "pushing" the gears one at the time. If you keep the pedal floored and changes just before the redline you hit the revlimiter and it is all poopie, if you lift the throttle when pushing in next gear you will get a real kick when hitting it again that causes wheelspin or you get two small kicks, one when the gear is in and one when you floor it again...
How do you guys run the A4 gearbox when running low 12 sec. times ???
Beginner at dragging as you hear...
/Tommy
Old Dec 3, 2002 | 06:09 PM
Joel Platts's Avatar
Joel Platts
Default Re: A4 Dragging Technique (C5Sweden)
I had a b&m prostick installed in my car so that I can bang through the gears without having to worry about missing a shift. This allows me to keep my foot on the gas through the whole pass. If your bouncing off the rev limiter, shift a little earlier and see if that helps. If your tires are breaking loose get some drag slicks. These will give you much better traction and where your safety is concerned I would highly recommend these. If you can't get the power to the ground it isn't doing you any good.
Good luck :thumbs:
Joel
Old Dec 3, 2002 | 06:41 PM
YO-EL's Avatar
YO-EL
Default Re: A4 Dragging Technique (Joel Platts)
How ya doin bro...!:seeya
I used to play hockey in Stockholm, Gotenberg & all over Sweden, "back in the day" for Team USA....
Anyway, my car runs 12.0-12.1 these days, and all I do is put it in "3", take off TC/AH, & FLOOR IT the whole time......
Pretty simple... try it....
Old Dec 3, 2002 | 06:49 PM
C5Sweden's Avatar
C5Sweden
Default Re: A4 Dragging Technique (indypace78)
indypace78
So you are familiar with the cold Swedish winters then I understand, just a long wait before you can take out the Vette again.
I am not sure I understand you correctly but are you starting in third gear ???? :confused: :confused: :confused:
Old Dec 3, 2002 | 07:58 PM
YO-EL's Avatar
YO-EL
Yes my Swedish meatball...
If you have an AUTOMATIC, (A4) it STAYS IN "3" !!!!! :yesnod:
Old Dec 3, 2002 | 08:32 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
:iagree:
Old Dec 3, 2002 | 08:57 PM
robtx's Avatar
robtx
Default Re: A4 Dragging Technique (Mr Mojo)
Do you guys run with "Traction control" on or off?
Old Dec 3, 2002 | 09:40 PM
kp's Avatar
kp
:iagree:
Except I leave it in OD, not so bad when you let off :) Just floor it and go..
Old Dec 4, 2002 | 10:37 AM
Dave00C5's Avatar
Dave00C5
I just leave mine in drive. Unless your running some super high gear it will never shift into od in a quarter mile! :cheers:
Old Dec 4, 2002 | 01:51 PM
YO-EL's Avatar
YO-EL
Default Re: A4 Dragging Technique (Dave00C5)
Well, whatever works for you guys....
I keep mine in "3"... during burnouts & the entire race....
TC/AH OFF.....
Old Dec 4, 2002 | 04:23 PM
urslooow's Avatar
urslooow
Default Re: A4 Dragging Technique (robtx)
TC/AH should be off for dragging :smash:
Old Dec 4, 2002 | 06:26 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Depends on track conditions I've run alot this year with the traction control on, You'll run slower but atleast you won't spin.
Old Dec 4, 2002 | 06:59 PM
vstella's Avatar
vstella
ALWAYS KEEP THE TRANSMISSION IN "3"..RIGHT THROUGH THE TRAPS.. :yesnod:
BTW..If you haven't installed a Transgo shift kit yet....Do it!!! :smash: It makes all the difference :yesnod: More info on the Transgo shift kit hre..http://www.txchange.com/transgo.htm
Old Dec 6, 2002 | 12:35 AM
JR-CRUZN-C5's Avatar
JR-CRUZN-C5
I use "3" and launch from dead idle up to 1200 RPM - did a lot of testing and that seems to be the best.
60' times are consistantly in the 1.7 range!
JR
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
To A4 Dragging Technique
