Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
LS1 Edit vrs Trans Problems
Old Dec 17, 2002 | 11:26 AM
RPM Frank's Avatar
RPM Frank
Default LS1 Edit vrs Trans Problems
In a few 98 and 99 vehicles with modified transmissions and High stall torque converters we have seen a pretty fair percentage that have shift point and rev limiter issues, some vehicles were easily repiared with a quick and basic programming change, others have not and still continue to have sparatic problems. All appropriate and standard software changes are being made including Torque management, Gear ratio/Tire diameter along with Vehicle Speed vrs Shift points.
I'm asking of anyone who may have had this problem to please post the prodution date and last 8 numbers of thier VIN, we are looking for a common denominator that has proven to be fairly elusive as of yet. We feel we are on the right track, but do not want to proceed further without some additional feedback.
This issue has not effected 2000 on up C5's that we have seen to date nor has it affected LS1/LT1 F-bodies and earlier LT1 C4's wich all use a variation of the same transmission bieng the 4L60E.
Thank you in advance for all your help, shared thoughts and experiences regarding issue being very welcome.
Frank@RPM :steering:
[Modified by RPM Frank, 11:31 AM 12/17/2002]
[Modified by RPM Frank, 11:52 AM 12/17/2002]
Old Dec 21, 2002 | 05:03 PM
RPM Frank's Avatar
RPM Frank
Default Re: LS1 Edit vrs Trans Problems (RPM Frank)
This post is getting very lonely ............. :nopity
Old Dec 22, 2002 | 12:31 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Good info. :yesnod:
Old Dec 22, 2002 | 06:00 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Unfortunately I don't have the electronically controlled trans in my car.
You may want to talk to Chris at ECS.
Old Dec 22, 2002 | 06:01 PM
c5man99's Avatar
c5man99
Default Re: LS1 Edit vrs Trans Problems (mackeyred96)
Frank,
I'm glad someone besides myself has discovered this problem! I have a modified 1999 coupe, everything but a stock bottom end. I have a ProTorque 2400-2800 with 3.73 gears. I am waiting on my new Yank ST3800 to be built.
I have Ls1 Edit and have used it exstensivly. I fixed the 2-3 shift at wot but the 1-2 is a problem. I also have the upgraded TransGo kit installed on my beefed up 4L60E. If you want to discuss this further, send me a phone # and a good time to call.
Old Dec 22, 2002 | 06:53 PM
RPM Frank's Avatar
RPM Frank
Default Re: LS1 Edit vrs Trans Problems (c5man99)
Thanks for the reply C5man99, thats exactly the problem we are seeing ourselves.
At first we thought we were making a mistake with the trans build, but then we started to see it on cars that were only converter equipped also. To make matters worse, it doesnt seem to follow any specific pattern, it just randomly happens.
The problem we've found is that PCM does not call for a 1st -2nd shift during the issue. But in running various scanning systems including AUTOTAP, we still have not been able to lock down on the cause. Thats why I asked for production dates and VIN#'s on cars being effected on this so way we may better narrow down the issue.
Call me anytime at 1-646-436-2811, It's currently Sunday evening just after you had sent your post, I'll be waiting.
Old Dec 23, 2002 | 09:48 AM
Eric Fischer's Avatar
Eric Fischer
You should post this in the C5 Scan and Tune Forum. Probably will get more exposure there.
[Modified by Eric Fischer, 9:50 AM 12/23/2002]
To LS1 Edit vrs Trans Problems
