I have an all stock 06 automatic with standard 2.5 gears out back.I plan on taking it down the track at Beech Bend in the spring. Id like to launch it with traction control off. What is it going to do on a prepped track ? Tire spin ? Bogg ? Or wheel hop ? Wheel hop is my concern. If it does hop is there an easy fix ? Id hate to break parts first time out. Ive done lots of racing but this is going to be a first time in a C6.
Iwould think the only simple thing you could do to help hook without changing your suspension around is going with a street radial slick.Otherwise i think your leaving a bunch of et off the table with you having to drive it out of the hole
