Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Wishbone or diagonal link ?
Old Feb 11, 2003 | 09:21 AM
GregP's Avatar
GregP
Default Wishbone or diagonal link ?
Anyone running a 4-link have a preference/recommendation? I currently have a diagonal link (very simple), but also have all the parts for a wishbone. Trying to decide if it's worth it to fab and install the wishbone or just leave the diagonal link in it?
Thanks - Greg
Old Feb 12, 2003 | 12:41 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Wishbone or diagonal link ? (GregP)
I'd leave the diagonal in. :yesnod:
Old Feb 12, 2003 | 10:56 PM
Blown Vette's Avatar
Blown Vette
Default Re: Wishbone or diagonal link ? (mackeyred96)
As a chassis man in a former life I can tell you with out question that you want a wishbone.
Old Feb 13, 2003 | 07:52 AM
GregP's Avatar
GregP
Default Re: Wishbone or diagonal link ? (Blown Vette)
Blown Vette - Can you elaborate on advantages/disadvantages a little? Always like to learn more about this stuff.
-Greg
Old Feb 15, 2003 | 08:23 PM
Blown Vette
-Greg
In a Corvette, the frame is very narrow, making a drag link extremely short. Such a short link causes the rear end to move right to left in the frame as much as two inches through the suspension travel. The panhard rod has no place on a very narrow rear frame, but it can be used on wider rear frames. I like to use a wishbone whenever possible. A wishbone will always keep the rear end centered through its full travel.
With that said a 4-link should not be used for street driving, it is unsafe. The ends will suffer fatigue from the force of turning and break when stressed at the track. Limited use can be obtained with frequent end replacements but that gets very costly. This is something few will tell you as they are in the business of selling parts/service.
The above opinion is base on real life experience I obtained during my employ as a professional chassis fabricator. I respect other opinions and would be curious to see why the above post recommended that you keep what you have.
Old Feb 16, 2003 | 10:56 AM
GregP's Avatar
GregP
Blown Vette -
I agree that the panhard is not an option with my narrow (20" wide) rear frame. A diagonal link (across the two lower 4-link bars) doesn't have the side-to-side travel problem, but in playing with it on my CAD system it does make the rear roll center be offset to which ever side has the rear of the diagonal. Since I had the parts and it was snowing out I went and fabbed and installed a wishbone yesterday (I'll add the pictures to my web page as soon as I can talk the "webmaster" into doing an update :) ).
The 4-link binding in roll problem only occurs with the angled link geometry used for drag racing. A parallel 4-link (as typically used in street rods) rolls without binding. With my suspension there is enough adjustability to allow an almost parallel link geometry for normal street driving, and I can easily drop the forward mounts of the upper links to move the lift center aft for racing when needed.
Thanks for your comments.
-Greg
To Wishbone or diagonal link ?
