Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Flash stall?????
Old Apr 22, 2003 | 04:35 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Flash stall?????
Ok, you bought a 3000 convertor or so you thought but is it really a 3000???
Question does your convertor flash stall where it saids it stalls????
Mind wasn't close :mad
Old Apr 22, 2003 | 04:44 PM
J Z06's Avatar
J Z06
Mine is 2800. It's right on the $.
Old Apr 22, 2003 | 07:25 PM
ralph's Avatar
ralph
Default Re: Flash stall????? (Jay D 90 383)
mine is supposed to be 2800 and it's pretty close.
Old Apr 22, 2003 | 08:02 PM
QuickVet's Avatar
QuickVet
Default Re: Flash stall????? (ralph)
how do you tell?
Old Apr 22, 2003 | 08:19 PM
mackeyred96
Default Re: Flash stall????? (QuickVet)
how do you tell?
Launch from an idle and watch the tach to see at what RPM the car starts to move.
Old Apr 22, 2003 | 08:58 PM
J Z06's Avatar
J Z06
Default Flash stall????? (mackeyred96)
how do you tell?
i burned up two rossler 700's doing just that!(LOTS of idle punches) :D on street tires and a high torque motor, that technique can be quite fun. :auto:
Old Apr 22, 2003 | 09:37 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Mine's a 2800, if I remember right it hits at almost 3000.
Old Apr 22, 2003 | 11:39 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Re: Flash stall????? (mackeyred96)
I will take a look next time out as I usually load the converter but started flashing recently.
Old Apr 23, 2003 | 01:42 PM
Face's Avatar
Face
Default Re: Flash stall????? (REDGAR)
My SY3500 used to flash at 3600.
Old Apr 23, 2003 | 02:45 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Mackey-
Are you using your stock tach to measure RPMs?? When I compare the actual RPM from the computer, to what my tach shows, the tach is a good 300-400 off. Heard the stock tachs are terrible..
-Mark
Old Apr 23, 2003 | 05:21 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: Flash stall????? (MarkLT1)
Mackey-
-Mark
You are correct Mark, all factory tachs are off by at least 200 rpm, that was done on purpose, some are more, Mackey's was off by 500. He has an aftermarket tach in his car.
Old Apr 24, 2003 | 10:04 AM
mackeyred96
Default Re: Flash stall????? (Mr Mojo)
Mackey-
-Mark
:yesnod: :yesnod: :yesnod:
Old Apr 24, 2003 | 11:39 PM
Beach Bum's Avatar
Beach Bum
John, my Vig is a rated 3000 rpm, but the 1st rpm I see on a hook pass is in the neighborhood of 3600 rpm.
Converters are without a doubt a big variable.
later
Beach
Old Apr 25, 2003 | 08:52 AM
C5 CU's Avatar
C5 CU
i had a Yank3000 and when I stomped on the brake, pulled the emergency brake and then gave throttle until motor bogged...stall was at 2800rpms.
Old Apr 25, 2003 | 08:23 PM
mackeyred96
Default Re: Flash stall????? (C5 CU)
Ya, but what does it flash?????
Old Apr 28, 2003 | 03:25 AM
8T1-7T9 BIONIC VETTE's Avatar
I'm using the Super Yank 3500 and it flashes at 3000 rpm..3500 rpm....I don't watch the tach much since I use my light most of the time....The few times I've watched the tach it's close to the flash point.....I never preload the car.....always launch from idle.....within a second the light flashes and I'm into second gear. I love the way that Super Yank 3500 hits.....very hard. :flag :seeya Cappy
Old Apr 28, 2003 | 05:45 PM
mackeyred96
Default Re: Flash stall????? (8T1-7T9 BIONIC VETTE)
THANKS everyone.
We'll see how this one does ;)
To Flash stall?????
