Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
new best e. t.
Old May 4, 2003 | 11:46 PM
MC TORCH RED's Avatar
MC TORCH RED
Default new best e. t.
three passes tonight trac/control was ok tonight. 12.56@108 12.58@107 12.63@108 just killed a stock 02 z06 twice. holeshot was working tonight .540 light . .568 light. also 60ft was down a little 1.76 and 1.77..............sorry bruce maybe next week.
Old May 5, 2003 | 01:48 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: new best e. t. (MC TORCH RED)
Catch you a viper next. :hurray: :hurray: :cheers: :lolg:
Old May 5, 2003 | 02:15 AM
MC TORCH RED
Default Re: new best e. t. (LittleBoyBlu99)
i think i'm going to get a few more mods like headers and ls1 edit before i go snake hunting......don't want to get snakebit. :nonod:
Old May 5, 2003 | 02:53 AM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
Mitch - this is good news! :cheers: Wait until you get headers and tuning - the numbers I predicted for you are there for the taking! :thumbs: :hurray: :flag
Gary
Old May 5, 2003 | 03:00 AM
MC TORCH RED
Default Re: new best e. t. (gary brown)
what should my 60ft. be at. so far 1.76 1.76 1.77 1.79 on nitto's at 20lbs.
Old May 5, 2003 | 07:29 AM
Mitch C's Avatar
Mitch C
With your converter and gears high 1.6 to VERY low 1.7 60 ft. times can be yours. If you are getting wheel spin try lowering your tire pressure in 2 PSI intervals. Are you brake stalling your car or flashing the converter from idle?
[Modified by Mitch C, 6:33 AM 5/5/2003]
Old May 5, 2003 | 10:20 AM
MC TORCH RED
Default Re: new best e. t. (Mitch C)
I LEAVE AT 2000 RIGHT NOW . WHAT SHOULD I LEAVE AT.?
Old May 5, 2003 | 11:33 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Good numbers :thumbs:
Old May 5, 2003 | 01:11 PM
Mitch C's Avatar
Mitch C
Try flashing from idle, the ST3500 does better when you flash it, at least it does in my car. If you flash it I am pretty sure you will have to lower your tire pressures because the converter will hit your tires quite a bit harder.
Old May 5, 2003 | 01:37 PM
urslooow's Avatar
urslooow
Good runs. It always feels good to set a new low ET! Now lower those tire pressures boy! try 15 psi. Alot of BFG 315 boys runat 12 psi, with no problemas!
Old May 5, 2003 | 01:39 PM
MC TORCH RED
Default Re: new best e. t. (urslooow)
thanks guys..
Old May 5, 2003 | 01:59 PM
tabbruzz's Avatar
tabbruzz
Headers will help a lot!!!! Good times...Congrats
Old May 5, 2003 | 04:03 PM
vstella's Avatar
vstella
....Now lower those tire pressures boy! try 15 psi.
:iagree: I run my Nittos at 15 psi and a good 7-8 second burnout..Gives me 1.60-1.63 60' every time..Also... launch at 1200-1500 rpm's...no more!:D
Old May 5, 2003 | 04:15 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
:cool: :cheers:
Old May 5, 2003 | 05:51 PM
MC TORCH RED
Default Re: new best e. t. (GrandSportC3)
thanks guys i think i will flash the t/c on friday night. maybe i will get some 1.60's will let you all know .......... :yesnod:
Old May 5, 2003 | 06:04 PM
J Z06's Avatar
J Z06
That's covering some ground quickly :cheers: :auto:
Old May 5, 2003 | 06:29 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Great times :thumbs: ..I was talking to a very knowledgeable vette mechanic today and he said if your brake fluid is even the slightest bit low, when we launch real hard, the computer may sense a problem and it will turn on the ARS even if we have disabled it...just a thought...I'm checking mine tonight... :D
[Modified by golfboy1, 6:30 PM 5/5/2003]
To new best e. t.
Old May 5, 2003 | 06:43 PM
QuickVet's Avatar
QuickVet
Nice Job :cheers:
Old May 5, 2003 | 06:55 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Wat to go :thumbs: Keep us posted. :yesnod:
Bob
Old May 5, 2003 | 10:38 PM
MC TORCH RED
Default Re: new best e. t. (16Again)
will do. :yesnod:
