Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Drag radials ?????
Old Jun 15, 2003 | 08:10 PM
plumberh2o's Avatar
plumberh2o
Default Drag radials ?????
Do you drive through the water with nittos or around water.
I just got drag radials and don't know the right thing to
heat them up. I don't have line locks.
KENCAN :confused:
Old Jun 15, 2003 | 08:11 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Drag radials ????? (plumberh2o)
Ken, with DR going through the water is OK.
Old Jun 15, 2003 | 08:19 PM
plumberh2o's Avatar
plumberh2o
Default Re: Drag radials ????? (mackeyred96)
DO I go around and then back up into the water or is that not
good with the track? Should I install line locks? :confused:
Ken Can :confused:
Old Jun 15, 2003 | 08:20 PM
mackeyred96
No, drive through the water, the track will not let you back into the water box.
A line loc is a good thing to have.
Old Jun 15, 2003 | 09:32 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Ken the water helps but try not to pick up too much. Just roll through or very slight blip of the throttle while rolling through.
Old Jun 15, 2003 | 10:48 PM
KyleBst264's Avatar
KyleBst264
I'm running BFG dr's and the stock tires up front. I ALWAYS drive around the puddle because those 9.5 inch wide tires in the front can track a whole lot of water up to the starting line.
Old Jun 15, 2003 | 10:59 PM
jpee's Avatar
jpee
Default Re: Drag radials ????? (KyleBst264)
When I had the 3000 converter I'd go through the water & heat the tires, because I HAD to, in-order to prevent wheel spin..
However now I have a stock converter, & am still using BFG 315 DRs & I go AROUND the water because I do a VERY SHORT burn out, & its hooking up OK..
& besides why go through the water and do a burn out if you can hook up by going around it.. & save your tires..
If I should ever have a traction problem, then I will go through the water & heat em up... but as of now with my set up, I save my tires.. & still get traction..
Old Jun 17, 2003 | 08:50 PM
plumberh2o's Avatar
plumberh2o
Default Re: Drag radials ????? (Red96Coupe)
Traction is my problem my 60FT times are from 1.84 to 2.23 Going
around the water.I have315 35R 17 Drag Radials,Stock convertor,
307 RearAnd aprox 240 HP @ WW & 336 lbs torque. What am I doing
Wrong? :confused: :banghead:
[Modified by plumberh2o, 8:52 PM 6/17/2003]
Old Jun 17, 2003 | 09:40 PM
Red Rocket's Avatar
Red Rocket
Roll thru the water and dump the clutch at 3000 rpm's in 2nd gear on my six speed. Consistent 1.7's on good track nights. The difference between 20 PSI and 17-18PSI is a .1 in the 60' on my 315 BFG's.
[Modified by Red Rocket, 8:41 PM 6/17/2003]
Old Jun 17, 2003 | 11:19 PM
jeffsc5's Avatar
jeffsc5
Default Re: Drag radials ????? (Red Rocket)
You dump it at 3000 in 2nd?? I've only been to the track once but always took off in 1st. Is taking off in second a big help?? the best 60 I got was 1.947 but I think I can do better!
Old Jun 18, 2003 | 09:54 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Re: Drag radials ????? (jeffsc5)
"dump at 3000 in 2nd"
I think he's talking about the burnout phase.... :confused:
Old Jun 18, 2003 | 10:07 AM
Red Rocket's Avatar
Red Rocket
Default Re: Drag radials ????? (Fuzzy Dice)
Dumping the clutch to spin the tires a little and heat them up. Launch at 2500 rpm's. Keep in mind the launch is with 380 LBS of torque at the wheels and 4.09 gears.
Old Jun 18, 2003 | 04:59 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I shift during my burnout into 2nd and stay at 4000 rpm for 5 - 10 seconds for a nice burnout...
Old Jun 18, 2003 | 06:35 PM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
:iagree: :iagree: :iagree:
To Drag radials ?????
