Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
ET Streets question..
Old Jul 6, 2003 | 01:34 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default ET Streets question..
Is anybody here running the ET Streets without tubes?
Old Jul 6, 2003 | 01:49 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: ET Streets question.. (GrandSportC3)
:yesnod: :yesnod: :yesnod: :yesnod: :yesnod: :yesnod:
Old Jul 6, 2003 | 02:56 AM
QuickVet's Avatar
QuickVet
Default Re: ET Streets question.. (mackeyred96)
you wont need tubes oliver. just make sure you mark the tire near the valve stem so you can see if the tire has slipped at all.
Old Jul 6, 2003 | 07:35 AM
mackeyred96
Default Re: ET Streets question.. (QuickVet)
I've got mine screwed to the rim.
Old Jul 6, 2003 | 10:07 AM
GrandSportC3
Thanks!!!
I still haven't decided if I will go with ET Streets or not... I might just get a new set of Drag Radials.. but I'm not sure... I would like to drive the car to the strip (400 miles round trip) a few times and I don't know if the ET Streets are save for such long trip..
[Modified by GrandSportC3, 10:08 AM 7/6/2003]
Old Jul 6, 2003 | 10:13 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
The CCW package is sold without tubes and without screws
Old Jul 6, 2003 | 09:52 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: ET Streets question.. (REDGAR)
no tubes, no screws, no problem :) :) :)
Old Jul 6, 2003 | 10:47 PM
GrandSportC3
Default Re: ET Streets question.. (CHRIS NJ C5)
:thumbs: :thumbs:
[Modified by GrandSportC3, 10:47 PM 7/6/2003]
Old Jul 7, 2003 | 03:30 AM
gary brown's Avatar
gary brown
From: Los Angeles Founder, West Coast Corvette Challenge
I have driven mine at freeway speeds, over 200 miles round trip with no problems at all. Just don't do this if the roads are wet! :eek:
Gary
Old Jul 7, 2003 | 11:40 AM
GrandSportC3
Default Re: ET Streets question.. (gary brown)
Gary
I don't even drive my Drag Radials in rain...
Old Jul 7, 2003 | 08:26 PM
Bowtie8's Avatar
Bowtie8
I assembled my brand new ET's and they where leaking through the little rubber **** in the side walls. I called Mickey and they said there is no garentee that they will hold air. hmmm. Well they wouldnt return them because I already had about 10 passes on them. My fault, didnt wait for a week to see if they would hold air.
Last year, my older set of ET's I ran them with no tubes and no-problem.
Now I am running tubes and screws in my nice Welds and they hold air. Got to screw them though.
Best Regards
John
Old Jul 11, 2003 | 06:36 PM
LOTAHP's Avatar
LOTAHP
Yo Oliver!! I'm running E.T.'s without tubes & without screws and haven't lost any air in them and they sit for almost a month between uses. I was told that once you start climbing over 500hp they should be screwed or you might get screwed!! So far I have not gotten screwed!! I'm running 12lbs in them and I noticed in Tracey's video that off the line they are doing some serious wrinkling. I'm getting some Ansen sprints next week and will probably screw them and get tubes. I think tubes will prolong the life of the side wall. I did have a buddy find the sidewall starting to split and he was losing air,(with no tubes) after how many runs I don't know, but it was a mustang with alot of spray. :steering:
Old Jul 11, 2003 | 11:41 PM
GrandSportC3
Default Re: ET Streets question.. (lotahp)
I might stay with Drag Radials... The potential issues with the ET Streets don't sound like fun... Haven't decided yet... Will see...
Old Jul 12, 2003 | 11:47 AM
LOTAHP's Avatar
LOTAHP
Oliver, there really isn't any "issues" with e.t.'s. Like anything else, do it right and you won't have any issues. E.T.'s should have tubes and to be safe they should be screwed. If your going to use an extra set of wheels, you should defenitly go with e.t.'s. They defenitly have a softer compound that obiously will give you more traction. I wouldn't drive either drag t/a's or e.t.'s on the street here in florida because at any given moment you can hit rain and forget about it, with either tire. After all this I hope we're talking about your c3. :cheers:
[Modified by lotahp, 4:53 PM 7/12/2003]
Old Jul 20, 2003 | 03:36 AM
8T1-7T9 BIONIC VETTE's Avatar
GrandSportC3.....
I'm running MT ET Streets without screws and tubes.
However I do not go below 20 psi tire pressure....
If fact on one of my 11 sec passes, I forgot to let the air out.....ran with 35 psi....so letting air out really doesn't matter to me.
I will continue to run without screws and tubes as long as as I stay with high pressure in my tires.....If I ever go below 20 psi I will use tubes and screws....since I watched a guy do the wall at the bottom of the quarter and over 100 MPH......It was not a pretty sight...He had 10 PSI on drag radials...and no tubes no screws...Common sense should prevail out there.....Tires have to have air in them to stick the bead to the rim.....10 to 12 psi is very low pressures for a tire to stay on the rim. :flag :seeya Cappy
Old Jul 20, 2003 | 09:25 PM
GrandSportC3
Default Re: ET Streets question.. (8T1-7T9 BIONIC VETTE)
GrandSportC3.....
I would not run them with less than 15 psi anyway...
Old Jul 28, 2003 | 02:24 AM
StrkrBlueC5's Avatar
StrkrBlueC5
I am running DR and have had some problems recently hooking up. Raising the HP is the investment to ET streets make that much of a difference? If so should I run tubes and screws? Expectations of 600 hp. What are your thoughts?
Old Jul 28, 2003 | 08:52 AM
GrandSportC3
Default Re: ET Streets question.. (StrkrBlueC5)
If you have problems hooking up.. ET Streets should give you a lot more traction.. They are basically slicks...
To ET Streets question..
