Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Newbie time question.
Old Jul 18, 2003 | 09:15 AM
93aqua's Avatar
93aqua
Default Newbie time question.
I have been looking at my time slips and I don’t understand, how is it that I have slower 1/4 time but higher speeds. For Example: I ran 14.4 at 98mph. And I lost to someone who ran 96 mph at 13.5. These aren’t accurate numbers I'm just using them for example. If I'm at a higher speed shouldn’t I get there first? :confused:
Old Jul 18, 2003 | 09:39 AM
INSANITY's Avatar
INSANITY
Default Re: Newbie time question. (93aqua)
Looks like the car cut a better light then you then at the top end was hard on the brakes. Thats how that works.... :)
Old Jul 18, 2003 | 10:02 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Automatic cars will always have lower speeds with the same ET than manual transmission cars...
Here's a actual example:
ET of an automatic car:
11.98 @ 112.9 mph
ET of a stick car:
12.06 @ 116 mph
Type of transmission is one big factor.. and gearing is another...
Old Jul 18, 2003 | 10:04 AM
GrandSportC3
Default Re: Newbie time question. (GrandSportC3)
You can even run mid 12's with less than 100 mph... :D :D
Here is a actual timeslip:
Well - I had clutch linkage problems.. and wasn't able to shift..
[Modified by GrandSportC3, 10:06 AM 7/18/2003]
Old Jul 18, 2003 | 10:25 AM
QuickVet's Avatar
QuickVet
some cars are quicker, some cars are faster ;) :D
Old Jul 18, 2003 | 10:26 AM
93aqua's Avatar
93aqua
Ok now its starting to make sense.
Old Jul 18, 2003 | 11:58 AM
PRNDL's Avatar
PRNDL
All of the factors mentioned above are important. With our corvettes, there are big differences in the power curves of the different engines. I have noticed that the L-98 engines (1989 up to 91?? ... not sure) seem to produce very good low end torque, but not a lot of top end power, so many of those cars are in the mid 13s at under 100 mph. In my case, with a 68 bigblock, even tho it is "supposed" to be producing a ton of torque, my typical run is 14 seconds at 102 mph.
Old Jul 18, 2003 | 12:46 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I sometime run a faster 1/8 mph than 1/4 mph on the same run.
Maybe Ralph can explain that one ;)
Old Jul 18, 2003 | 01:13 PM
INSANITY's Avatar
INSANITY
Default Re: Newbie time question. (mackeyred96)
Sometimes? I'd say most of the time. :lol:
Old Jul 18, 2003 | 01:24 PM
ralph's Avatar
ralph
It's all explained in the press release in this thread:
http://forums.corvetteforum.com/zerothread?id=603995
Old Jul 18, 2003 | 05:34 PM
mackeyred96
Default Re: Newbie time question. (INSANITY)
:eek: :eek: :eek: :eek: :eek: ;)
Old Jul 18, 2003 | 05:35 PM
mackeyred96
In most cases we only run fast enough to WIN :hurray:
Old Jul 18, 2003 | 09:28 PM
jpee's Avatar
jpee
Being serious for a moment... I think he is talking about an ALL OUT run ..& not hitting the breaks...
Traction & chassis set up is the key factor to running quick ET.. Horse Power will give you higher MPH..
Example.. my 96 is really close to stock.. (stock heads & cam) but it has run as quick as 12.28 but only 110 mph.. now if you look at a LT1 or LS1 with NO2 & street tires, it will probably run 117-120 but still the same ET as me..
The difference is..in the 60' time I'm quicker in 60' but he has more HP and is going faster than me at the 1/8 mile & will be gaining on me the 2nd half of the track..
Look at NHRA records.. you will see cars running very quick ET but not as much MPH as you think they should..
In reality their MPH is good.. but their ET is FANTASTIC in comparison to the MPH.. the reason is they have a GREAT chassis set up & they are putting ALL their HP to the track..
Maybe one of the guys with a TRACK car can explain it better than I did..
[Modified by Red96Coupe, 9:29 PM 7/18/2003]
Old Jul 19, 2003 | 08:43 AM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Traction.
Old Jul 19, 2003 | 05:39 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
:seeya Dan...we met at the Fl Challenge when you came down...Insanity is correct..the guy you lost to was measuring the stripe...he let off the throttle or was on the brakes....in the last challenge I had a run of 14.64 @ 99.03 mph and 2 runs later I went 13.76 @ 92.80...this is because I was racing my opponent and trying to just clip him at the stripe...bracket racing is all about the win light, not ET's or mph...good luck
To Newbie time question.
