Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Line lock
Old Jul 21, 2003 | 09:30 AM
SuprJames's Avatar
SuprJames
Default Line lock
What's a good line lock system or are they all about the same? I was looking at them in Jegs and I realized that I really have no idea what makes one better than the other or if there's anything special I need.
Old Jul 21, 2003 | 10:30 AM
jpee's Avatar
jpee
Default Re: Line lock (SuprJames)
I think they are all very similar, I used to use a Hurst Roll Control, but it leaked twice on me, & now I'm using a TCI & have had it for 3+ yrs with NO problems..
Also the TCI is much smaller & more compact.. I did not have to mount the relay to anything, CarTech just mounted it right after the master cylinder to the front break line.. & its fine..
There are 3-4 Co. that make em.. but bottom line I think they are all ok..
Old Jul 21, 2003 | 12:09 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Line lock (Red96Coupe)
I have the cheapo Biondo Linelock.. It was leaking initially but haven't had any problems since... It was only around $40 and works great!!
Old Jul 21, 2003 | 02:23 PM
SuprJames's Avatar
SuprJames
Default Re: Line lock (GrandSportC3)
Thanks for the info guys. I'll put it to good use!
Old Jul 21, 2003 | 08:04 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I have the Hurst inboth of mine, only problem I've had is overheating, but that may be due to the fact that the solenoid was mounted too close to a heat source.
To Line lock
