Reaction Time Questions
What is considered a good reaction time where you would not make changes?
What is the reaction time difference between staging deep vs. shallow on a 13 second C5?
Just went racing after being away 35 years. Wow that was fun. Ran a 13.46 in bone stock C5 with best reaction of .665
Now I trying to figure out how to get into the 12s :D
Thanks for any input provided.
Most bracket races usually use .500 tree so that is perfect.
A good reaction time in which you would stop making changes does not exist. You are constantly adjust for well you are seeing the tree, tractino on the line and how your car is responding on that day. How close you want to get to perfect is really dependant on the the competion. In one class you may be able to go far with any light in the .5 range, another you need .550 or better and yet others if cannot hit a .5teen light you are in trouble.
Not sure what the light difference deep vs. shallow. I would guess may .05 to .15
Enjoy the racing. PS, staging deep will get you slower ET so if you want to improve ET and RT, stage shallow and leave a little sooner.
Q) What is a perfect reaction time? .5 or .4
A) .500
Q) What is considered a good reaction time where you would not make changes?
A) In order to get a good reaction time you shouldn't make changes but do the same thing everytime. I look for a .540 or better, that will win you alot of races.
Q) What is the reaction time difference between staging deep vs. shallow on a 13 second C5?
A). NONE, reaction time is reaction time of when you brake the starting line beams. all deep staging do is get you closer to the starting linr and that let you see a full 3rd amber on launch. On a shallow stage you leave on the first flash of amber.
Q) Now I trying to figure out how to get into the 12s
A) That hasn't changed in 35 years all it takes is money to go faster.
What is considered a good reaction time where you would not make changes? You should not be satisfied until you can stay below .600 on the full tree. Good drag racers can cut consistent .550s or less.
What is the reaction time difference between staging deep vs. shallow on a 13 second C5? I'm not sure about this but I thinks it's always best to shallow stage. Your ET will improve slightly (versus deep staging) but your reaction time will be a tad slower.
I don't agree with NJ VetteGuy as to spinning. You only need to move a few inches to trip the timers. Excessive spinning will certainly hurt your 60 foot times and ultimately your ET but the the effect on reaction time is nill.
A good way to improve your reaction time is to buy a tree simulator. I have a PT Pro from TAG Systems. The latest issue of Drag Racing Action has an article about tree simulators.
I guess the thing for me to do is: Stage shollow and learn to anticipate the 3rd light. Hopefully, lots of practice will make the RT better. :seeya
The reason people deep stage is to get better lights. Reaction time is the time it takes the driver AND the car to cross the start beam and when you put that car closer to the starting beam, like in deep staging, you will impact your RT.
I know you knew that:D
Mack, you are slipping here buddy.
As to spinning and reaction time: I'm looking at a time slip from this past Sunday. I raced a Viper, he jumped me with a .374 (red lighted) against my .533 so his reaction time was actually too fast. However his 60 foot time was 2.792 so it's clear he had little traction and was spinning excessively.
NO, NO, NO!!! It is called 'Reaction Time', NOT 'Aniticipation Time'...!!!
#1- Get yourself a 'practice tree', to take YOUR physical-reaction time out of the equation. If 'we', as people, could 'anticipate' THAT good, the delay-box industry would have NEVER materialized, and we'd ALL cut .5-ohs at will; I don't see that happening anytime soon.....
#2- Once YOU become consistent, begin varying your launch RPM, staging location (shallow, deep, or 'bump-in') until YOUR (physical) RT, coupled with the car's RT (drive-train 'slack', initial movement, etc.), and the 'staging position' deliver the RT on the time-slip that YOU want.
Think of these elements (RPM, stage-location, YOUR physical RT, etc.) as the elements used to strike a golf-ball (grip, stance, follow-thru, club-selection, etc.). Varying one element has effects on the others, as well...
Been there done that.
Most of you guys have much more drag experience than me, so I'll defer to your knowledge. But it doesn't seem logical that, no matter how much wheelspin you can generate, the front wheels won't break the beam immediately.
I know, excessive wheelspin hurts your 60ft. time. But to say that the front tires aren't going to move at all, or start moving late, because the rears are spinning, doesn't seem logical. :confused: :confused:
I've seen plenty of deep stagers go red. I would bet their percentage is the same as a shallow stager. It's all about know your car and yourself.
The closer your 'satisfactory window' is to perfect (.500), the more likely you 'may' foul, but your chances of victory is increased, too.
Discipline, ESPECIALLY in the 'no-box' classes, is crucial.... A 'good' foot-braker can go .5-teen/.520 repeatedly, but it WILL eventually 'catch-up' to even the best.....
What I meant was that maybe I need to trigger my response to the 2nd amber light. For example, if I stage Shallow and get my RPMs up where the wheels will spin a lot, that the spin delay from the 2nd Amber will give me a better reaction time. I know that I should have both a better ET and MPH if I get a running start at the 1/4 mile.
You mentioned an Electronic Delay Box. Are they legal? Do they work good?
On the subject of spin affecting R/Ts: remember the car must roll about 12-14 inches beofre breaking the R/T beams, so it is not instant and a lot can happen in those 12 inches.
No offense, but.... this is NOT the way to go racing...
Relying on the SAME amount of wheel-spin every-time will, more-than-likely, make you First Round Runner-Up with great frequency; here's why:
#1- "WE", as human-beings, aren't exact every run; we don't 'stage' the same, nor 'react' the same, from run-to-run...
#2- the 'car' doesn't react the same from run-to-run (bog, stumble, good-air/bad-air, etc.)...
#3- the 'track' isn't the same from run-to-run (sun, shade, 'leakers' in front of you, no traction compound, too-much traction compound, etc.)...
So, 'expecting' wheel-spin to 'correct' flaws in your staging, reactions, track, etc., is a tough proposition (at best!!!); if you can 'do' this, I tip my hat to your abilities...
I have a Z28 that goes 12.80s, with a 1.88 (average) 60' time, 'deep-staged' for good (.51-.53) RTs; 'shallow-staged', it goes 12.60s (?) with a 1.7-1.8 60', but my RTs end-up .58-.60, even WITH a 4500 converter & 4.10s.
I didn't infer that practicing would 'quicken' your RTs; just make them 'consistent', time-after-time. 'WE' (the drivers) are THE biggest variable in the RT quotient.
'Delay boxes' are legal in Super-Pro (NHRA) or Top (IHRA) bracket classes, as well as the " .90-Classes " (S/C, S/G, S/ST, etc.), but not legal in other forms of bracket racing. You 'leave' off the TOP bulb (no 'aniticipation' there!!!) from a button, and the box 'counts-out' a pre-determined amount of time (set by thumb-wheel) to result (hopefully) in perfect RTs every run. (If you are consistently .520, take .015 'out' of the box, to produce {theoretically} .505 RT)
Delay-boxes 'usually' improve a driver's consistency, but in those classes, most everybody can go .5-oh/.510, and everybody HAS to go .5-oh/.510, too, to be a threat to win not just the entire race, but a single round. I had one in my rear-engine dragster; they take all the 'fun' out of hitting a .5-oh light...
Just my $.02 worth.....
But when we start to get competitive, there are 3 elements of performance.
1. Equipment Performance: Getting best ET per HP/Weight which is recognized by Class Records.
2. Driving Performance: Getting good RTs
3. Tuning/Driving for the strip conditions:
With Bracket Racing we throw the first element out, allowing an 11 second car to be competitive when it should be running 9s. That just leaves tuning and driving.
I think if you are going to be a consistent winner you need to be able to adjust your launch based upon track conditions (sun, shade, 'leakers' in front of you, no traction compound, too-much traction compound, etc.). I agree this is not easy; but you can't avoid it.
Therefore, why not use this variable to get better RTs (if possible ?, this admitlly is pure bench racing at this point on my part).
One last opinion: I would really like to see these delay boxes legalized; since they do not really give an unfair advantage (they are not using a laser to watch the tree and doing the launch). The driver still has to be consistent and react to the lights.
In closing, I maybe all wrong; but hope to improve my RT any which way
:crazy:
