Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
What tire pressure..
Old Oct 14, 2003 | 09:53 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default What tire pressure..
.. should I run in my 165R15 tires at the track?? It says 32 psi maximum pressure.. but I'm thinking in going higher than that.. Does anybody have experience with those tires? Is it safe to run higher pressure than that??
Old Oct 15, 2003 | 12:11 AM
Glensgages's Avatar
Glensgages
Default Re: What tire pressure.. (GrandSportC3)
I assume you're talking about the front tires?
I run a Mickey Thompson 26" x 7" on a 3.5"-wide wheel on my '79 Z28; have run as much as 40+ PSI to 'adjust' RTs for eliminations.
WHATEVER you do, make sure your tires can handle the weight of your car.
I know guys who run 'VW-tires', 'front-runners', 'skinnies', etc., on cars with VERY heavy nose-weights.
My Z28 probably goes 2200+ pounds on the fronts; the MTs I have are made SPECIFICALLY for 'heavy' cars.
No sense in 'blowing-out' a front at speed due to incorrect tire-useage...
:thumbs:
[Modified by Glensgages, 3:16 AM 10/15/2003]
Old Oct 15, 2003 | 02:24 AM
lager99's Avatar
lager99
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: What tire pressure.. (Glensgages)
Why do you run front's higher? :confused:
Old Oct 15, 2003 | 04:14 AM
Glensgages's Avatar
Glensgages
Default Re: What tire pressure.. (lager99)
more PSI in the front = less rolling resistence = lower ETs.
You drop the rear PSI to increase your 'foot-print' slightly; all your fronts do is hold the car off the ground, and allow you to steer.
By raising/lowering the front PSI, you can (minutely) adjust the rolling-resistence to quicken/slow-down your initial 'move', or Reaction Time in bracket-racing...
Old Oct 15, 2003 | 08:39 AM
GrandSportC3
:thumbs:
Well - the Mickey Thompsons were designed for higher pressure..but my front runner tires are regular radials... I would need input from someone actually runnung 165R15's in front... I don't wanna risk blowing my front tires...
Old Oct 15, 2003 | 10:49 AM
lager99's Avatar
lager99
St. Jude Donor '06
Cool :thumbs:
Old Oct 15, 2003 | 11:28 AM
GrandSportC3
so - anybody with 165R15's here??? :seeya
Old Oct 15, 2003 | 02:27 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
You might better play it safe .
:thumbs: :iagree:
Old Oct 15, 2003 | 02:36 PM
GrandSportC3
Default Re: What tire pressure.. (LittleBoyBlu99)
I see lots of cars with more weight than mine running the same tires... Some of them even run 9's...
To What tire pressure..
