Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
ET Street, launch control?
Old Oct 24, 2003 | 05:34 PM
Carnage's Avatar
Carnage
Default ET Street, launch control?
What should launch at on 26x10.5 with 16" wheels? I used to do Rev limiter launches on my SS with 15" 26x10.5's at 10 PSI. I figure I'll run 10 PSI tonight.
Old Oct 24, 2003 | 08:03 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Re: ET Street, launch control? (Carnage)
As much as the clutch will take
Old Oct 25, 2003 | 08:30 AM
Face's Avatar
Face
I was told by M/T not to go under 12#, anything less and you could be using the sidewall on your launch.
Old Oct 25, 2003 | 02:14 PM
Carnage's Avatar
Carnage
Default Re: ET Street, launch control? (Face)
Was this from mechanic, tire tech, or hard core racer? I ran 10#, but it wasn't a low pressure gauge. I need to drop $30 and buy one.
By the way I ran a 12.93 and a 12.71. It's said that our track is at 4200 feet above sea level. And I launched at 3000. The first pass I did a weak burnout. I'm still learning the car. I Need to install the line lock. I just drove up the the water, pulled forward slightly, and dumped the clutch in 2nd at 4000, and John Forced it.
[Modified by Carnage, 12:17 PM 10/25/2003]
To ET Street, launch control?
