Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Racing harness ''Pull Up'' or '' Pull Down''
Old Jan 10, 2004 | 08:13 PM
z-u-later's Avatar
z-u-later
Default Racing harness ''Pull Up'' or '' Pull Down''
for a 5 pt cage do I need a pull up or pull down harness when ordering as well as a 55'' or 66'' w/ a bolt in or wrap around I'm confused :crazy: .
It will be for a 5 pt cage!!------------------------------------------------------------------------------------------------------- :banghead:
Old Jan 10, 2004 | 08:44 PM
kh24's Avatar
kh24
Default Re: Racing harness ''Pull Up'' or '' Pull Down'' (z-u-later)
Didn't i give you a link to the harness to buy. Go buy that one and I will help you tape it and hot glue it in like i did with mine :crazy: :lol: :D
Old Jan 10, 2004 | 11:52 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: Racing harness ''Pull Up'' or '' Pull Down'' (kh24)
:lol: :lol: :lolg: :thumbs:
Old Jan 11, 2004 | 01:23 AM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Racing harness ''Pull Up'' or '' Pull Down'' (LittleBoyBlu99)
:lol:
Old Jan 11, 2004 | 02:35 AM
LittleBoyBlu99
Default Re: Racing harness ''Pull Up'' or '' Pull Down'' (MC TORCH RED)
What you laughing for " you going to need them to.
:lol:
:cheers: :yesnod: :p: :p: :hat
Old Jan 11, 2004 | 09:30 PM
joeflyer's Avatar
joeflyer
Pull-down is if you tighten the belts yourself. Pull-up is if you have a crewman do it for you. If your cage has mounting tabs with holes, you need bolt-in. Can't tell you about the length, but if you get the longer belts, the slack can be taken up easily.
Old Jan 12, 2004 | 05:08 PM
z-u-later's Avatar
z-u-later
:crazy:
O.K. I have the tape & the glue now what.---------------------------------------------------------------------------------------- :banghead:
Old Jan 12, 2004 | 08:17 PM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
If you pull up, You have the chance of knocking yourself in the face with your hands when pulling up. You may also slip and hit the roof. Always pull down.
Old Jan 12, 2004 | 08:23 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
The link kh24 gave you is the most popular we use. It is pull down and warp around
Old Jan 12, 2004 | 08:28 PM
kh24's Avatar
kh24
Default Re: Racing harness ''Pull Up'' or '' Pull Down'' (REDGAR)
Here is the link if anyone else needs it. Comes with all the hardware to install. Its a cam lock too so its easy to get in and more important easy to get you out of incase of an emergancy. http://store.summitracing.com/partde...t=RCI%2D9210CB
Old Jan 12, 2004 | 10:48 PM
z-u-later's Avatar
z-u-later
:thumbs:
To Racing harness ''Pull Up'' or '' Pull Down''
