Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
recommended engine temp with iron heads ?
Old Jan 14, 2004 | 11:02 AM
mike 1985's Avatar
mike 1985
Default recommended engine temp with iron heads ?
last year my 85 would run 185 in town and 212 with the A/C on. I have added 100 extra HP over the winter, so i'm thinking i need more cooling. I measured the origional radiator and it's 1" thick. i TOOK THIS TO MY LOCAL RADIATOR SHOP AND THE REPLACEMENT ONE IS 1-3/8 THICK for $150. Do you guys think this is worth the money ? What other options are out there ?
I did have about 1" of debrees( leaves) between the bottom of the rad and condensor which is now cleaned.
What do you guys feel the optimal operating temps are ? I have a 160 stat and was thinking of going to a 180 ?
