Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
launch technique?
Old Jan 16, 2004 | 02:51 PM
FD boy's Avatar
FD boy
Navigator
Default launch technique?
I was going to try my Z06 out at the drag stip and was wondering what a good launch technique might be for the stock tires and stock car.
Done anybody have an opinion?
thanks
:flag
Old Jan 16, 2004 | 03:57 PM
98VETTEC5's Avatar
98VETTEC5
Default Re: launch technique? (FD boy)
I'm courious also! TTT
Old Jan 16, 2004 | 05:00 PM
Red Rag Top's Avatar
Red Rag Top
If you do search under "launch" you will find all kinds of advise.
Old Jan 16, 2004 | 05:58 PM
ROJO99's Avatar
ROJO99
Lets see, :rolleyes: I have the following input.
October, Mid 70's
Run 1, 60' 2.234 launch at 2200-2500.
Run 2, 60' 2.350 launch at 2500-2600.
Run 3, 60' 2.250 launch at 1800-1900.
Run 4, 60' 2.313 " "
Run 5, 60' 2.251 launch 1500-1600.
I am finding that I need the leave the line rather soft, get rolling then mash it.
The last few runs where bad. I had one slip with a 14.1 :bb . I had to lift twice in first, once in second and on the 2-3 shift... It was a little hairy. Hope this helps, and good luck.
All times are with a 99 MN6, Stock except for a Blackwing. Traction will be your biggest hurdle.
Old Jan 18, 2004 | 02:02 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
You have to learn how to slip the clutch alittle off the line then hammer it. Try leaving at 3500-4000 rpm and slip it " this should get you some good decent 60ft's in the 1.8 range on FI Super Tires.
Old Jan 18, 2004 | 02:03 PM
LittleBoyBlu99
Welcome newbie and keep Practicing". :cheers: :thumbs: :steering: :hurray:
Old Jan 18, 2004 | 04:20 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Welcome to the forum :thumbs:
Old Jan 19, 2004 | 12:01 PM
ROJO99's Avatar
ROJO99
Do not forget to post some results. :flag
Old Jan 19, 2004 | 02:42 PM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
IMHO you want to have the PSI in the rear tires down to 20-22 lbs with 40-45 in the fronts to help with weight distribution.
I also suggest that you go through the water box and try to heat the tires up some.
I have an MN6 and if I launch at more than about 2200 rpms I get wheels hop.
Good luck and stay safe!
:cheers:
To launch technique?
