Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Mickey Thompson E/T and Tubes
Old Feb 12, 2004 | 09:43 AM
Blue Flame-less Joe's Avatar
Blue Flame-less Joe
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Mickey Thompson E/T and Tubes
Of you running Mickey Thompson E/Ts how many of you are running tubes with them?
Old Feb 12, 2004 | 10:42 AM
LOTAHP's Avatar
LOTAHP
Default Re: Mickey Thompson E/T and Tubes (Blue Flames)
I'm running Mickey Thompson E.T. Streets 28 x 12.5 x 15 @ 12lbs. No tubes, No screws, No problems. I have some tubes for sale if you would like.
Old Feb 12, 2004 | 11:10 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I run my E/T Streets with tubes and no screws, but I have to keep higher pressure in them because of that.. I don't want to f up my rims with screws, so - what I might end up doing is that I'll remove my tubes so that I can drop the pressure without worrying about the tires spinning on the rims and cutting off my valve stems...
Old Feb 17, 2004 | 04:11 AM
Power Shifter's Avatar
Power Shifter
Default Re: Mickey Thompson E/T and Tubes (GrandSportC3)
:thumbs: Remember you still need metal valve stems at -11.99 without tubes. Ric
[Modified by Power Shifter, 4:13 AM 2/17/2004]
[Modified by Power Shifter, 4:15 AM 2/17/2004]
Old Feb 17, 2004 | 05:19 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Screws, no tubes here :thumbs:
Old Feb 17, 2004 | 07:25 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
No tubes, no screws.
Old Feb 17, 2004 | 09:04 AM
LOTAHP's Avatar
LOTAHP
Default Re: Mickey Thompson E/T and Tubes (REDGAR)
Metal valve stems :thumbs:
Old Feb 17, 2004 | 09:49 AM
GrandSportC3
Default Re: Mickey Thompson E/T and Tubes (Power Shifter)
I have metal valve stems.. so there's no problem... :D
Old Feb 17, 2004 | 10:25 AM
Blue Flame-less Joe
What pressure are you guys running? :grouphug:
Old Feb 17, 2004 | 10:28 AM
GrandSportC3
I was running 17 - 18 psi with tubes and no screws (to prevent the tires to spin on the rim), but I will go with 15 psi or less without tubes... I know that Norm (lotahp) runs 12 psi :eek: :eek:
Old Feb 17, 2004 | 10:32 AM
Blue Flame-less Joe
What kind of 60' times are you running with that pressure?
Old Feb 17, 2004 | 10:42 AM
GrandSportC3
I usually get 1.64 with 17 - 18 psi but I'm spinning every single launch..
(used to get 1.50's with Drag Radials... :rolleyes: )
I'm sure that I'll get 1.50's as soon as I remove the tubes and run lower pressure... Another option would be to screw the tire on, but I have no intentions on f'n up my rims...
Old Feb 17, 2004 | 10:58 AM
Blue Flame-less Joe
I've been running consistant 1.7 with nittos with a little spinning so maybe this will got me to 1.6. Thanks for the info. See ya this weekend I hope
Old Feb 17, 2004 | 11:07 AM
GrandSportC3
I hope so too.. However - I haven't found somebody to split a hotel room with.. I want to keep my cost down...
The forecast for Saturday also doesn't look too great.. 40% chance of rain...
If I come up - I'll bring my C5 and not the C3... :(
[Modified by GrandSportC3, 11:09 AM 2/17/2004]
Old Feb 17, 2004 | 11:58 AM
98NYFINESTVETTE's Avatar
98NYFINESTVETTE
From: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
If you are running a stick car and have M/H on the rear - You should have tubes and screws. Slower cars running street tires and M/H don't really need tubes and screws. At the track during the 2003 season some racers marked there tires early in the day. Later in the day the tires turned about 2 to 3 inches. The cars where high 12 and mid 13 second Vettes. So as you can see the balance will be off without the screws due to the tire rotating around the wheel. I hope this will help you. :)
Old Feb 17, 2004 | 02:35 PM
GrandSportC3
Default Re: Mickey Thompson E/T and Tubes (89NYFINESTVETTE)
The only problem is that the holes in the rims make them almost unsellable...
Old Feb 17, 2004 | 10:25 PM
QuickBlack85's Avatar
QuickBlack85
Could not have said better Rob, screws and tubes new for me this year.
To Mickey Thompson E/T and Tubes
Old Feb 17, 2004 | 10:42 PM
hookedup's Avatar
hookedup
Default Re: Mickey Thompson E/T and Tubes (QuickBlack85)
No tubes-no screws :D
Dave :thumbs:
Old Feb 18, 2004 | 03:57 AM
Power Shifter
Default Re: Mickey Thompson E/T and Tubes (hookedup)
One more tube fact; there are tubes and then there are raceing tubes. Race tubes are much softer natural ruber and can hold heat, they allso can have an effect on sping in the tire. I usually ran tubeless, but there are some positive things you can get from them, if the car isen't hooking satisfactory tubless. Food for thought, Ric
Old Feb 18, 2004 | 01:21 PM
LOTAHP's Avatar
LOTAHP
No tubes, no screws, steel valve stems, @ 12lbs., 60' 1.57 , 500+ hp, living on the edge. :D
I do have the racing tubes hanging in the garage and will probably use them soon.
[Modified by lotahp, 1:24 PM 2/18/2004]
