Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
When to replace BFG Comp. DR
Old Feb 19, 2004 | 10:04 PM
z-u-later's Avatar
z-u-later
Default When to replace BFG Comp. DR
I have the 17 X 315 Comp BFG Drag Radials, Not sure when to replace them, Should they be on the track when they are bald threw & threw? I sthat the good part or should they be replaced before completely down to no treads?
Old Feb 19, 2004 | 10:18 PM
jpee's Avatar
jpee
Default Re: When to replace BFG Comp. DR (z-u-later)
I use the exact same tire, I change them when all the tread is worn off, ONLY because I have to drive 100 miles home... but if you change them at the track, or don't have far to drive you can get a lot more runs out of them..
Old Feb 19, 2004 | 10:20 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
They are just staring to get good. You can race on them till you see cord.
Old Feb 19, 2004 | 10:37 PM
z-u-later's Avatar
z-u-later
Default Re: When to replace BFG Comp. DR (REDGAR)
Thank You thats exactly what I wanted to here.. :cheers:
Old Feb 20, 2004 | 07:00 AM
RichS's Avatar
RichS
For me once the tread went away, the tires got much less consistant for me and don't stick as well.
To When to replace BFG Comp. DR
