Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Hooking Up!!!
Old Feb 25, 2004 | 04:13 PM
TONYDEE64's Avatar
TONYDEE64
Default Hooking Up!!!
Hi guys, I'm new to this forum and I have a question for you....
I have a 1991 C4 6-speed that has a full heim joint suspension that has rear adjustments for everything, camber, caster, toe. I also have coil overs with Bilstein shocks.. I will be running 315 BFG DRs. I bought this car in pieces 18 months ago and have not yet had in on the street yet... Are there any tricks to setting up this suspension to get it to hook... I have a supercharged 532" big block that (hopefully) will be cranking out over 1000hp on pump gas... Is this a lost cause trying to get this much power to the ground?.. I can make an engine run but I am totally lost on suspension tuning... See my thread in the Forced Induction C4 forum "Procharged Big Block" for pictures..
Thanks!!!!
Tony
Old Feb 25, 2004 | 05:19 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Hooking Up!!! (TONYDEE64)
take that car to a good chasis shop and put in at least a ford 9 inch and hold on :cheers:
