Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
anyone manually shift their a4 while racing?
Old Apr 14, 2004 | 03:15 PM
1fastmfc5's Avatar
1fastmfc5
Default anyone manually shift their a4 while racing?
does it make a difference?i was told it would go a little faster or is that bs,or will i just kill my tranny?
Old Apr 14, 2004 | 05:38 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Re: anyone manually shift their a4 while racing? (1fastmfc5)
Unless your shift points aren't set correctly, I can see no reason to shift manually...the computer never makes a mistake and it can shift a lot quicker than we can...
Old Apr 14, 2004 | 06:02 PM
jpee's Avatar
jpee
Default Re: anyone manually shift their a4 while racing? (Fuzzy Dice)
I have a 96 that is electronically shifted, I can set the shift points & leave it in D However if you dont have an electronically shifted trans...i.e. 93 then most people I know use a shift light..
Old Apr 14, 2004 | 06:04 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I'm not good enough to shift mine, the computor is faster.
Old Apr 14, 2004 | 06:51 PM
J Z06's Avatar
J Z06
I manually shift mine.
The shift points "SHOULD" be at 5800 punched in my car. That is the one area my tranny shop lacks knowledge in.
Old Apr 14, 2004 | 06:58 PM
CFI-EFI's Avatar
CFI-EFI
I shift mine. I got in the habit when the old trans shifted to 2nd at 3400 rpms. I haven't tried letting it shift itself since I got a new trans, two years ago. If the auto shift points are appropriate, being lazy is more consistant.
RACE ON!!!
Old Apr 14, 2004 | 08:34 PM
jpee's Avatar
jpee
Default Re: anyone manually shift their a4 while racing? (mackeyred96)
With an auto I dont think you "HAVE" to be fast... just look at the tach & push it to next gear when it hits your shift RPM.. I only think you have to be FAST & coordinated is on a 6 speed!
I don't think an electronic auto can shift ant faster than "ANY" human as long as he/she can look at the tack & push the shift lever when the rpm hits the shift point.. OR put in a shift light....duhhhh & push the handle when you see the light...
"IF" you are really slooooooooooooo.. set the shift light to go off 200-400 RPM BEFORE you want to shift...
Common John ..you knew that.... You dont have to be "FAST" to shift an auto...
Mackey
Old Apr 14, 2004 | 08:59 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Default Re: anyone manually shift their a4 while racing? (Red96Coupe)
You can not out work that comp" so leave it in 3rd and lay back and have fun
Old Apr 14, 2004 | 09:31 PM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default Re: anyone manually shift their a4 while racing? (LittleBoyBlu99)
Okay, point taken. But what about those of us with '93 and earlier... leave it in 3(no computer controlled shifts)? BTW, tranny is stock.
Old Apr 14, 2004 | 11:28 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Default Re: anyone manually shift their a4 while racing? (eschoendorff)
I have a 93...my tranny shifts at 5900 rpm, wide open throttle ...with 3:73 gears that puts me through the traps at 5900 rpm...just at red line...only perfect...I had my tranny rebuilt and beefed up last fall and it shifts lightening fast...
The red line on a stock 93 is right at 5900 rpm or so...you need to put it in 3rd (regular D) and see what rpm you are shifting at under WOT...also what rpm you go through the finish line at...if you are shifting too soon then you may want to try manual shifting..
If your 1-2 and 2-3 shifts are at or near redline with the computer doing the shifting, your fine...I don't know what gear ratio you have in your car but if it is less than 3:73 you will go through the traps at a lower rpm...since my swap to a Dana 44 with 3:45's I am going through the traps at a measley 4800 rpm...tomorrow morning my car goes in the shop to have new 3:73's put in like I had in my old Dana 36....I'm tired of lollygagging along in 3rd gear at WOT...
Old Apr 15, 2004 | 12:21 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
More like 3000 rpm before you want to shift, the 700R4 will hit the rev limiter before it shifts,even if I shift at 2000 rpm. I leave it in "D"
Old Apr 15, 2004 | 12:39 AM
jpee's Avatar
jpee
Default Re: anyone manually shift their a4 while racing? (Mr Mojo)
Thats a totally different trans than the 4L60E I also have a Hypertech chip & set mine for "firm shift" & its perfect!
Old Apr 15, 2004 | 10:32 AM
CFI-EFI's Avatar
CFI-EFI
I'm not positive about the 4L60E, I think it would apply to the "E" also, but the 700R4/4L60 shifts with the same quickness at WOT, regardless of whether the next gear is manually selected of if the trans decides the shift point. Being "good" is not a factor in a "fast shift".
RACE ON!!!
Old Apr 15, 2004 | 12:19 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
The A4 on my '98 shifts exactly at 6000 RPM...
Old Apr 15, 2004 | 12:38 PM
jpee's Avatar
jpee
Default Re: anyone manually shift their a4 while racing? (CFI-EFI)
I'm not good enough to shift mine, the computor is faster. I'm not positive about the 4L60E, I think it would apply to the "E" also, but the 700R4/4L60 shifts with the same quickness at WOT, regardless of whether the next gear is manually selected of if the trans decides the shift point. Being "good" is not a factor in a "fast shift".
RACE ON!!!
On a 4L60E shifting done by the computer, however on earlier models the computer has nothing to do with the shift point, & its hit or miss thats why in NON computer trannys it might be better to manually shift, in computer controlled cars let the comp do it. it DOES NOT SHIFT QUICKER THAN A HUMAN! only more consistent!
Old Apr 15, 2004 | 07:02 PM
CFI-EFI's Avatar
CFI-EFI
I'm sure my non "E" is more consistant than *I* am. We agree, then, that the "quickness" of the shift is not a factor in auto or manually selected shift points on an A4.
RACE ON!!!
Old Apr 15, 2004 | 11:04 PM
MC TORCH RED's Avatar
MC TORCH RED
leave it in 3rd and hang on, you can't outshift the brain in your car.....
To anyone manually shift their a4 while racing?
Old Apr 15, 2004 | 11:17 PM
jpee's Avatar
jpee
Default Re: anyone manually shift their a4 while racing? (MC TORCH RED)
What about those guys who "DONT" have a "BRAIN" (computer controlled) trans ?? You & I have "Brains" i.e Computers) that control the shift, but older Vettes are shifted by valve bodies (mechanical) and may not shift at the optimal shift point... (most dont shift at the correct RPM)
Tracy Lewis's daughter drives a 7 sec dragster with all the latest Hi Tec. Electronics Delay box, trans break, etc...
Lets see if that is shifted by a computer "Brain" or a Teenage girl
Tracy.. help us out..
Old Apr 16, 2004 | 07:41 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Hey John...when your finished asking Emily if she shifts her dragster ask if she shifts the C5 when she drag races...
Old Apr 16, 2004 | 08:54 AM
jpee's Avatar
jpee
We KNOW SHE DONT SHIFT THE C5 its a Computer controlled car..I'm trying to make a point to the others who have computer control shifts who say "Let the Computer Shift" I agree but what about those who do NOT have computer controlled trannies?
Sure some shift at or close to the red line ..but what about those whose valve bodies are not set correct, & the car is shifting at 4200... do you spend $$ and have a tranny shop screw with it 4-6 hrs.. or just shift when the shift light flashes at 6000... I vote for a $40 shift light...
[Modified by Red96Coupe, 8:55 AM 4/16/2004]
