Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
ET Streets on a C5
Old Apr 25, 2004 | 03:49 PM
HawkIVette's Avatar
HawkIVette
Default ET Streets on a C5
Looking to get some info on ETStreets for my 99. What brand and size are you C5 owners using? Especially looking for input from owners that have used drag radials compared to ET. Which did you find worked better?
Also would consider slicks, but don't know enough about what's available out there. For those using 16"rims, I understand you have to grind down something on the car to gain clearence? Explain more on that.
[Modified by HawkIVette, 3:09 PM 4/25/2004]
Old Apr 25, 2004 | 07:40 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Re: ET Streets on a C5 (HawkIVette)
CCW drag package, sizes in sig with ET Streets.
Drag radials worked great for me, switched to CCW setup for lighter front wheels and more consistent for bracket racing 60's
[Modified by REDGAR, 7:40 PM 4/25/2004]
Old Apr 25, 2004 | 07:47 PM
HawkIVette's Avatar
HawkIVette
Default Re: ET Streets on a C5 (REDGAR)
As far as the CCW wheels, they fit on the C5 with no problem or did you have to modify (grind) the car?
Old Apr 25, 2004 | 08:57 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
The CCWs I have have are 16" and there is some grinding needed. MT does make a 17" that requires no grinding however and I am not sure if ccw has a wheel for it.
they are at http://www.ccwheel.com
Old Apr 26, 2004 | 08:27 AM
HawkIVette's Avatar
HawkIVette
Thanks edgar, That link helps alot. Shows just exactly what to do.
You're the man.
Old Apr 26, 2004 | 11:33 AM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Glad to help
Safe racing
Old Apr 26, 2004 | 03:01 PM
DRAGRACR's Avatar
DRAGRACR
Just get you a set of late model Firebird 16" rims and some 26-11.5-16 ET Streets and go racing. They fit fine.
Old Apr 26, 2004 | 07:30 PM
HawkIVette's Avatar
HawkIVette
Default Re: ET Streets on a C5 (DRAGRACR)
I have been contemplating that very thing after Edgar's help and suggestion. Thanks DRAGRACR. I just might take your excellent advice.
Old Apr 26, 2004 | 11:20 PM
wht2000vette's Avatar
wht2000vette
What does everyone think about the 17 et streets
Old Apr 26, 2004 | 11:23 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Hawk one thing to keep in mind is that the mix of radial fronts and bias ply rears is a very unual feeling at that the top end. The car will tend to sway more so than with bias ply all around. If you do mix the tires, be careful up there.
Old Apr 29, 2004 | 01:08 PM
HawkIVette's Avatar
HawkIVette
Thanks Edgar, I'll keep that in mind. I did locate a pair of 16" Firebird wheels with Mickey Thompson ET STreets, so it looks like that's the way I will go.
If I put bias ply tires on the front, are you saying it would be better than mixing the radial/ bias? I can see why that would make sense, just want clarification.
Old Apr 29, 2004 | 01:09 PM
HawkIVette's Avatar
HawkIVette
Default Re: ET Streets on a C5 (wht2000vette)
That's what I originally wanted. Just try to find them right now. Everybody is back ordered till mid June.
Old Apr 29, 2004 | 02:29 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Yes bias ply up front will make the car roll better.
Old May 2, 2004 | 02:58 AM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Old May 2, 2004 | 11:59 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: ET Streets on a C5 (LittleBoyBlu99)
I prefer the 16" over the 17" because you have more size wall to flex.
My .02 cts!
Old May 7, 2004 | 09:20 PM
HawkIVette's Avatar
HawkIVette
Default Re: ET Streets on a C5 (wallstAL)
Well, I finally got some 16" firebird wheels with ET Streets on them. Have started the "grinding" to get them to fit. Hopefully be able to try them out this weekend. Thanks guys for the input and the advice.
To ET Streets on a C5
