Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Package question...?
Old May 30, 2004 | 12:58 PM
YO-EL's Avatar
YO-EL
Default Package question...?
Ok, I know your package is the difference in your ET vs your dial added to your RT... Example> 12.0 dial ET 12.05 .100 light. Package =.105
Question, what is your package if you break out?
Example> 12.0 dial, ET 11.95, .100 light???????
Thanks for the explanation......
Old May 30, 2004 | 03:20 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
Default Re: Package question...? (YO-EL)
It is my understanding they do not figure a packge on a break out....you break out, you lose...on a double break out the winner is decided only by who breaks out by the least amount vs. their dial...R/T's are not included...
Old May 30, 2004 | 07:51 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Packages mean nothing it all about who wins.
Old May 30, 2004 | 07:59 PM
YO-EL's Avatar
YO-EL
Default Re: Package question...? (mackeyred96)
Was just asking a question..
I'll assume Dan up there is correct..
Old May 30, 2004 | 08:49 PM
jpee's Avatar
jpee
How can you win with the worse package.... duhhhhhh
That makes NO sense.. the best package will always win.. unless of a breakout or other infraction!
You lost yesterday because your opponent had a .0009 BETTER package !! Think about it...
Like Fuzzy said if there is a breakout package dont matter... or if someone crosses the center line.. BUT if neither car breaks out, & there is NO red light the best package will always win..
Old May 30, 2004 | 09:40 PM
Vic'89's Avatar
Vic'89
I dont understand that statement, a good package means a great deal.
Vic
Old May 30, 2004 | 10:00 PM
mackeyred96
Default Re: Package question...? (Red96Coupe)
That makes NO sense.. the best package will always win...
Thats my point. As long as you win rounds, packages are unimportant.
Have agreat package and still lose it means nothing.
Old May 30, 2004 | 10:26 PM
Glensgages's Avatar
Glensgages
...Packages mean nothing...
I once had an NHRA track-operator tell me this very same thing;
that "racer's math" didn't work...
When he was awarded the NHRA Division 1 Track Operator of the Year Award that season, I just
[Modified by Glensgages, 10:27 PM 5/30/2004]
Old May 31, 2004 | 07:41 AM
YO-EL's Avatar
YO-EL
Default Re: Package question...? (Glensgages)
Ok, then riddle me this race fans....
Racer A cuts a very poor light, 2/10 slower than his opponent, & runs 2/10 over his dial.
Racer B with the 2/10 better RT runs .08 faster than his dial in number..
Can racer A get to the finish line 5/10 ahead of racer B????
Is that possible?
Old May 31, 2004 | 09:53 AM
Glensgages's Avatar
Glensgages
Is that possible?
Only if the track had a timing system malfunction...
I'll try to make it as simple as possible...
Both Racer 'A' and Racer 'B' have dial-ins of 14.00
Racer 'A' cuts a .700 light (on the 'older' .500 system), and runs 14.200 on his 14-flat dial;
Racer 'A' has a 'package' of .400 (.200 on the tree, and .200 on his run)
Racer 'B' cuts a perfect .500 light (2/10s better than Racer 'A'), but runs 13.920 (.080 faster than his dial) on his 14-flat dial-in.
While Racer 'B' has a better 'package', the 'break-out' (running quicker than his dial) over-rules this fact, just as would a foul-start.
Racer 'B' would hit the stripe .480 seconds ahead of Racer 'A':
Racer 'A' had a .400 package, and Racer 'B' broke-out by another .08 (.400 = .080 = .480)
{Think of running-under as hitting a baseball 700', but into foul territory...impressive, but not worth a damn...}
I believe the above 'theoretical' ET slip would show a Morgin-of-Victory of .280 seconds:
.200 that Racer 'A' was "to-the-good", and .08 that Racer 'B' run under...
Does that help?
Old May 31, 2004 | 09:54 AM
CFI-EFI's Avatar
CFI-EFI
I don't see where you derive the numbers to ask a .500 question.
Racer A has a .400 disadvantage. A .200 slower light plus the .200 over his dial. Racer B gets to the finish line .408 ahead of racer A. Racer A wins, because racer B broke out. The B lane crossing first by .408 comes from the .200 better tree, plus the deficency in A's ET/dial of .200 plus the .080, under his dial, break out. It's all simple arithmetic.
RACE ON!!!
[EDIT] Speaking of "simple arithmetic", I AM aware that .400 + .080, does NOT equal .408. Opps!
[Modified by CFI-EFI, 9:49 AM 5/31/2004]
Old May 31, 2004 | 11:17 AM
YO-EL's Avatar
YO-EL
Default Re: Package question...? (CFI-EFI)
Glensgages is correct with timing or tree malfunction...
The faster dialed car's tree must have went off later than the dial in differential in my example.
Both racers numbers on the slip would appear to be correct,> based on when they broke the starting beam, but only a delayed tree could account for racer A getting to the stripe 1st & the large MOV..
Thanks...
Old May 31, 2004 | 01:47 PM
Glensgages's Avatar
Glensgages
I'm not sayin' I'm right, an' i'm not sayin' that I'm wrong...
but if you 'leave' on your opponent, and run-under/further-under than your opponent...
Ain't no-how he's taking the stripe first, unless there is an equipment/timing system glitch (i.e.: wrong haed-start, electrical problem, etc.).
To Package question...?
