Desktop Racers...
383 stroker @ 9.5:1
Shifting at 5500 - 5800 RPM ( limiter set at 6000)
Super ram and 58 mm tb
Hooker 2149's
335 rwhp/ 480 (nitrous)
410 rwtq/ 585 (nitrous)
3.33 gear
zf6 speed
Centerforce dual friction clutch
BFG DR's 275/40/17 @ 20 psi hot
I should be able to pull 1.6x 60 foot times too right?
I know you've all seen these and some of you probably hate these, but my car has never ran right, and I know it has way more potential in it than it is showing.
So this is to humour me / make me hang my head in shame for not running as fast as it should.
I did have a previous Mustang dyno of 305 rwhp/398 rwtq but it was "pinging really bad" (what the operator said), so looking at similar setups, I guessed at the 335/410 numbers.
Check out the American Super Car Challenge at www.rollingthunderz.com/ascc.html
N2O = 9.478
But if you let the air pressure in those rear tires down to 18 pounds, you'll really be cookin'.
RACE ON!!!
I just want something to shoot for cuz I'll keep tinkering with it until it's right. I didn't think my expectations were unrealistic.
I have posted what it runs in other posts, but I forgot to mention it in this one.
N/A on BFG KDW's second time out bogging it off the line so I wouldn't spin, I only got a..
60 foot --- 1.971
330 foot ---5.811
660 foot ---8.511
660 mph ---84.947
1/4 ET -----13.226
1/4 mph ----105.391
And, on the only day I tried nitrous, the first run I had a nitrous "pop" in my super ram which messed up my MAF, but the second run, I could only get a 60 foot in the high 1.8's and ran a 12.8 @ 108. The car felt sluggish and is getting worse.
I asked what I should run, because if everyone feels that I should only be running what I am, then I won't keep at my mechanic and tell him things are wrong, but if it's supposed to be like a full second better than what I am running I'd like to know.
Speaking of the computer, I hooked a laptop with Datamaster up to it, and it's pulling 7 degrees of timing at WOT. How much would that hurt performance?
Take it serious or not CFI, but I'm sure someone won't mind helping without joking. That's what makes this forum great.
RACE ON!!!
RACE ON!!!
Would you have guessed 12.2 @ 110 mph... no.. but there is what CFI-EFI is talking about...
If your car is set up the way you said
>>383 stroker @ 9.5:1
Hooker 2149's
3.33 gear
zf6 speed
BFG DR's 275/40/17 @ 20 psi hot<<
I think you are about 1 sec slow.. using my 96 as a comparison, I ran 12.2 on a motor with NO mods, so off hand I'd say you have some tuning issues..
Ralph (another forum member) has run 11.60 with a 350, cam, heads & Super Ram intake.. Bottom line if you paid for the engine work, I dont think its running up to its potential... Talk to your engine builder ....
I see you are a 6 speed & I'm automatic, my 60' was 1.65 with drag radial, you should be at least 1.70 with a stick, & if you spray iy 1.5
