Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Confusing time slips. What's wrong
Old Nov 1, 2004 | 09:34 AM
SG4206's Avatar
SG4206
Originally Posted by X_03_Cobra_guy
My thoughts were that I should be shooting for 11.40's with the MPH. Granted, it
I put 4.71 gears in it and a 4000K stall and trans brake ans slicks, I could probably run 10's but this is a street car. My original goal was to beat a Z06 with
an automatic, but that has turned out to be harder than I origianlly thought
You usually find out the first couple seconds of reduced ET isn't too hard to attain ; because you can throw money at it with know speed parts and see good results.
I think you have pretty much reached the point where you have to decide whether to spend more money on HP to lower ETs , or money on drive train to make the current combo more efficent. Either way , you can lose some streetability; or all of it.
A looser convertor will lower your ets. One that flashes to around 4500 rpm should cut at least .3 of a second. The engine will be at a higher HP out put, accelerating harder from 60' to the 660'. Look at your dyno sheets and compare HP at 3500 and 4500. Torque gets the car moving ; HP is how fast it happens.
Old Nov 1, 2004 | 05:42 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
4.71 gears is a lot of gear, no??
When I had my Mustang, putting 4.10's in it made me a bit nervous, especially as it was my daily driver...
Old Nov 1, 2004 | 08:19 PM
robz's Avatar
robz
Wheelspin. I once trapped 122mph with headers,gears,vararam,and bfg's. (364 rwhp) My 60' foot was poor and attributed to the high trap speed.
Old Nov 3, 2004 | 12:04 AM
X_03_Cobra_guy's Avatar
X_03_Cobra_guy
I think wheelspin is playing a role in my high trap and high et. I will give
a better track and better weather a try first. Then I might invest in CCW
drag package. I think the excessive wheelspin on the 1-2 shift is hurting
too. Thanks guys for all the help. Lots of good info!
