Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Drive shaft loop?
Old Nov 8, 2004 | 08:27 PM
Marlin in Minn's Avatar
Marlin in Minn
Default Drive shaft loop?
Does anyone have one of these on their C4? My local track hasn't really hassled me about it, but it's my understanding if you run slicks, you're supposed to have one. Anybody have one and can you tell me how/where you mounted it and possibly post a pic?
Also, I've been reading in the NHRA rule book about half shaft loops. Section 1A, Drivetrain, Rear End...would lead me to believe that I'm supposed to have "axle retention loops". "Cars with independant rear suspension using upper and lower control arms may retain swing axle assembly regardless of weight or ET. Must have 360-degree minimum 1 inch wide by 1/4 inch thick axle retention loop on each axle". Then says "See General Regulations 2:11".
In general regulations 2:11 it says: After market axles and axle retention device mandatory on Top Fuel, Funny Car, etc.....(not going to quote the whole section here).., and 10.99 ET cars;also mandatory on any car (regardless of class or E.T.) with a spool".
Well, I'm not running a spool and my car runs 12 second ET's...this is very confusing..
Old Nov 8, 2004 | 08:40 PM
Joel Platts's Avatar
Joel Platts
Safety loops are pretty easy. Jegs and summit have them for not a lot of money. You can attach the main loop to the c channel that surrounds the drive shaft to fully enclose it. Or go to a local fab shop and have them build one for you out of tubing, that way it would fit and look good. That would be pretty trick!
As for the safty loops on the axle shafts, loops probably aren't a bad idea, again a fab shop can do it for you, but your probably allright without them. I think that if your running under a certain e.t. they are required, but I'm not sure how quick it is you have to be running. Hope this helps.
Keep it straight!
Old Nov 8, 2004 | 10:22 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Here's what Mr Mackey did with a universal loop kit from Summit for about $25-$30.
Old Nov 9, 2004 | 01:17 AM
SmokeGray89's Avatar
SmokeGray89
You can get one from ZR51 Performance.
http://www.zfdoc.com
Old Nov 9, 2004 | 07:32 AM
Mr Mojo's Avatar
Mr Mojo
Hmm, $179 vs $25, it's the same thing.
Old Nov 9, 2004 | 10:31 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
My local vete shop fabbed and installed mine for $90.00...can't get a pic of it but it looks sorta like Mackeys...
Old Nov 9, 2004 | 11:29 AM
CFI-EFI's Avatar
CFI-EFI
Mackay's would be perfect if it is within 6" of the front u joint. Half shaft loops are required at 10.99 on C4's. A different axle or a control arm fix on C3's.
RACE ON!!!
Old Nov 9, 2004 | 01:00 PM
Marlin in Minn
Thanks for all the replies!!
Based on the info and pics you all have provided I think I'm going to get the Summit loop ($24.50) and try to modify it to work similar to the one on the ZR51 web site. It won't look as pretty, but it should work.
It doesn't sound like I need to worry about half shaft loops, since I'm a long way from running in the 10's. ( Except in my dreams )
Thanks!
Old Nov 9, 2004 | 05:39 PM
Greybeard ZR1's Avatar
Greybeard ZR1
Thanks Guys, I've always wondered about this.
That bracket looks like a tight fit, but if it works, it works.
To Drive shaft loop?
