Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
HAL QA1's installed!
Old Nov 26, 2004 | 08:39 PM
Tony.96LT4's Avatar
Tony.96LT4
Default HAL QA1's installed!
Just got done install of HAL QA1's on my 96. Good thing I diid the fronts first. Had to use washers to shim out the bottom rears so they would tighten up. Other than that problem I'm impressed with the shocks. On rapid aceleration the front just raises slightly and the rear doesn't move. This is with the settings on 6 clicks from soft.
Overall I give them a
Old Nov 27, 2004 | 06:57 AM
RichS's Avatar
RichS
Normal driving I keep mine around 4. They do seem to be a good shock for multiple uses of the car. Glad I bought them in the spring.
Old Nov 27, 2004 | 07:56 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I am running 6 or 7 in the front on the street and 6 in the rear. Looser and I tend to bottom out.
2 in the front for the strip.
1 in the front is really bouncy on the track so be careful Tony
To HAL QA1's installed!
