What pistons with 3.8" crank?
Old Feb 4, 2005 | 09:31 PM
79VetteMike's Avatar
79VetteMike
Default What pistons with 3.8" crank?
I am looking to do something with this 400 block I have and have considered purchasing a 3.8" stroker crank. Does this require special pistons or what?
Old Feb 4, 2005 | 10:26 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Anytime you change the stroke of an engine, the piston pin height has to change. If not the piston will stick out of the hole.
Pops
Old Feb 5, 2005 | 11:59 AM
CFI-EFI's Avatar
CFI-EFI
NO! With a stroke .050" longer than the 3.75" 400 crank, the piston rises (and drops) .025" higher (and lower) in the bore. It is an ideal way to get a reduce the deck clearance to obtain a good quench area with minimal decking of the block. The advantage in the quench will be greater than the approx 6 cubic inches you'll pick up, and for less cost (I assume) than the greater amount of block decking. Good move.
RACE ON!!!
Old Feb 5, 2005 | 07:44 PM
Lt1er's Avatar
Lt1er
Look at the JE or wiseco sight and they might have them in their online catolog. George told me that his Wiseco pistons actually are -20 or 22 cc dished to keep compression down. Your going to end up with something under 415 ci without an overbore and you need to look at 15 or so cc dished to keep your compression down
Old Feb 5, 2005 | 08:00 PM
CFI-EFI's Avatar
CFI-EFI
As stated, he doesn't need a stroker piston for a .050" stroke increase.
How can you speculate on the piston configuration he may need, since he hasn't mentioned what heads he wants to use. Most piston manufacturers offer a variety of configurations. More that one dome size and more than one dish size.
With a typical, .030" overbore, the 3.80" stroke yields 412 CID. Less with a standard bore.
RACE ON!!!
Old Feb 6, 2005 | 02:29 PM
79VetteMike
I have Pro Topline aluminum 200cc/64cc heads. The crank I was looking at getting is a Cola superlight crank on Ebay. A guy from another board says that his buddy is also selling a Cola, because it would take too much mallory to balance it, but from the pictures, it didn't look like a superlight. I don't want to go this route if pistons are going to cost me $600+.
Old Feb 6, 2005 | 03:01 PM
CFI-EFI's Avatar
CFI-EFI
Reread posts #3 and #5 on the piston usage.
RACE ON!!!
Old Feb 6, 2005 | 03:06 PM
gkull's Avatar
gkull
RACE ON!!!
I beg to differ on this statement. I need correction mysef at times :o
Stroke is the offset from the main journal center line to the rod journal center line. An aditional .050 stroke would lift the piston .050 more in each direction. Which with the typical .025 piston to deck Your above the deck .025. That's not a problem. I have a friend with a race boat that uses .060 copper head gasket with an O-ringed block and that's how he got his quench height correct
Old Feb 6, 2005 | 05:07 PM
SWCDuke's Avatar
SWCDuke
No, that's the "crank throw radius", which is half the stroke. A stroke increase of .050" means a .025" increase in crank throw radius, which will raise the piston crown .025". If the block is not decked, typical flattop pistons usually yield about .025" deck clearance, so increasing the stroke .050" will yield about zero deck clearance. A typical composition head gasket will then give you minimum quench clearance and the CR will probably be in the range of 9.5 to 10.5 depending on whether you have large or small chamber heads.
Most pistons also have enough crown thickness that shaving the tops up to .025" to get your target CR or quench clearance will not reduce strength or reliability.
Duke
Old Feb 6, 2005 | 05:32 PM
CFI-EFI's Avatar
CFI-EFI
Duke
EXACTLY!!!
Thank you Duke, you saved me the trouble.
gkull,
See post #3.
RACE ON!!!
Old Feb 6, 2005 | 11:03 PM
gkull's Avatar
gkull
My math was out ot lunch, but at least Philly cover the point spread! I just wished i bet more.
To What pistons with 3.8" crank?
