I have always painted my engines using "engine paint."
I want to paint my engine a color that is not available in "engine paint" and was wondering if anyone has had good luck using a regular automotive paint?
Would it work to use a single stage urethane to paint the engine? I would hate to go to all the prep and paint work only to have it flake/fade after installing the engine for this summer.
Thanks,
Jeff
Reason: fat fingers...
I can't remember the details, but there is a way to use body paint on an engine and have it last. I don't recall if it was the paint, an additive, or a special clear. Keep looking there IS a way.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Normally don't post anything I have not done or seen myself but I was contemplating painting mine a custom color and when I asked around the general consensus was that you could use ordinary automotive body paint because it is pretty tough in the first place and a motor really doesn't get all that hot, except maybe around the exhaust ports. One reply I got was that custom car builders have been doing it for years.
I just had mine painted with regular automotive paint. The guy told me he's been doing street rods for years. I was kind of surprised, but I guess it works. Now that it's in the car, I realize I can hardly see it
[QUOTE=Caboboy]I just had mine painted with regular automotive paint. The guy told me he's been doing street rods for years. I was kind of surprised, but I guess it works. Now that it's in the car, I realize I can hardly see it
Yes, but you know how much time you put into it and how well it came out. You should take pride in your work knowing that you did the job to the best of your ability and even though people won't be able to see your work, you know it's there. Some of it will be seen and even though it's hard to take credit for something that cannot be seen, just knowing that it's there and you took the time to do it properly should make you feel good about yourself. And if this engine isn't for you and/or it's for a customer, he/she should be happy that you took the time to do this. I think it is a job well done.
The POR-15 co. I deal with a Lady in Sacramento who is a dealer. She really knew her way around this product. Prep is finicky, but its worth the end result. Blasted and sprayed my entire chassis and underside of the body with this stuff (not the engine paint). I'll have to check around to find a link www.por-15.com
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
I've done this before, painted a cherry red pontiac, painted our 283 V8 we installed with same cheap-o NASON paint. Just added twice the hardener to make it a littlemore resilliant. When the engine got dirty, you could just hose it off, and the glossy finish would let the grease, and grime come off. Cleaned up real nice. The paint was still in good shape 5 years later when I pulled the engine.
I took my T-top into a commercial Sherwin-Williams place and had them paint match the color. They put it in aresol cans, metal flake, and pearl as well! It worked really well. I have had the motor painted for over a year now and it has held up perfectly to oil, heat and road grime.
the key is to get the paint to last and look just as good years down the road, and to do that it takes prep. I've painted all my engines out of the car, took the motor down to bare metal, spray a nice self etching primer, then spray high temp enamel..looks great. I've also helped a friend spray his engine with primer sealer over enamel engine paint that was just scuffed really good, and then acrylic urethane color, and by a year it was chipping off bad.
