1990 Engine Rebuild
Old Mar 12, 2005 | 04:08 PM
moose1990's Avatar
moose1990
Navigator
Default 1990 Engine Rebuild
Need input on the rebuild of my 1990 L-98 engine. Car has 122K and engine has never been torn down. I have purchased a ZZ4 cam and Speed Pro H631-CP pistons, .030 over. Need advise on the rocker arm selection, pushrods, rods, computer chip, and any other advise that would be helpful prior to start of rebuild. Can engine be removed from car with hood in place? Thanks.
Old Mar 12, 2005 | 05:37 PM
CFI-EFI's Avatar
CFI-EFI
Yes. Any further parts selection will have to be based on your expectations and intended usage.
RACE ON!!!
Old Mar 12, 2005 | 07:41 PM
moose1990's Avatar
moose1990
Navigator
Car will be street driven only, would like to make 300 to 350 hp.
Car is auto with 3.06 rear end.
Old Mar 20, 2005 | 03:26 PM
69stingray's Avatar
69stingray
In regards to pushrods, rods, etc., call Summit Racing and get thier advance on parts. I would recommand getting some Vortec heads and a Vortec TPI manifold from Scoggin Dickey ( http://www.sdpc2000.com/ ), the Vortec heads with the ZZ4 cam would be a great match. You should be a little over 350 HP, but more importantly, you will have tons of low and mid-range torque. You may also want to look into a 1,000 cfm throttle body and headers/hi-pro muffler.
To 1990 Engine Rebuild
