(DD2000) Need intake manifold air flow data...
Old Mar 17, 2005 | 12:12 AM
MIKER's Avatar
MIKER
Default (DD2000) Need intake manifold air flow data...
Does anyone have the airflow data for the various intake manifolds? I want this information for Desktop Dyno 2000 data input.
Edelbrock Performer
Edelbrock Performer RPM
Victor Jr.
etc....
Cyliner head flow data would be handy to have as well.
Old Mar 17, 2005 | 01:05 AM
gkull's Avatar
gkull
DD2000 doesn't use flow for the intakes. I do have a Zip file on lots of popular heads that I could send you though.
Old Mar 17, 2005 | 03:22 AM
MIKER's Avatar
MIKER
I've just started playing with dd2k and thought that I could input custom numbers in the "Airflow Math Calculator" for intakes but I see that you can't. :o
I'll take you up on the offer for the head flow files!
Old Mar 18, 2005 | 09:17 AM
comp's Avatar
comp
i've never seen intake flow data , not that wasn't bolted to a head to test... would be interested myself
Old Mar 18, 2005 | 07:01 PM
Caboboy's Avatar
Caboboy
DD2K uses an intake style to locate the torque curve, but not flow. ie: single or dual plane...........
Old Mar 22, 2005 | 12:21 PM
comp's Avatar
comp
that kinda suck's , there is some flow differences between the different intakes
Old Mar 22, 2005 | 01:03 PM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
I've even called and asked Edelbrock about it, THEY don't even have flow numbers for the Edelbrock Performer, but DO for the RPM. I figure the Edelbrock Performer is just a stocker but made of aluminum and has "Edelbrock" on it:
Old Mar 22, 2005 | 11:06 PM
Caboboy's Avatar
Caboboy
Yeah, no doubt. But........if you really think about it, it doesn't matter what the intake flows if your heads choke it down. The only air going in has to go thru the intake port.
Old Mar 23, 2005 | 12:40 PM
comp's Avatar
comp
true,,, but i was thinking about balance and was the intake messing up the heads
To (DD2000) Need intake manifold air flow data...
