Please check my data for calculating compression ratio.
Crank: 3.75in stroke
Bore: 4.040
Rods: 5.7in
Heads: 52cc (I'm going with worst case since the heads were milled previously. I’ll get an exact number once the heads come back from being cc’ed. But they wont be more than 54ccs)
Deck clearance: .0001 (Block was zero decked with the prior 383 rotating assembly.)
Gasket Thickness .049in
Gasket Bore: 4.040 (I forget, is this always the same as the bore diameter or is it oversized by .010?)
Pistons with a 18cc dish.
So using the calculator at the following url: http://www.kb-silvolite.com/calc.php?action=comp
I get: 10.812:1 static compression ratio.
Anything blatantly wrong with the above assumptions? Is the compression ratio to high? This engine will be running an LT4 hotcam, will that bring down the effective compression ratio some? That same link has a option for figuring this out, but I don't have the cam specs needed.
Thanks,
52cc heads > 10.73:1
58cc heads > 10.06:1
64cc heads > 9.47:1
72cc heads > 8.8:1
Hopefully others will chime in for comparison of results.
Mike
You really dont' want that thick of a head gasket!
Calculate Compression Ratio
Bore
(Inches)
Stroke
(Inches)
Connecting Rod Length
(Inches)
Cylinder Head Volume
(cc)
Deck Height
(Inches)
Head Gasket Bore
(Inches)
Head Gasket Thickness
(Inches)
Piston to Cylinder Wall Clearance
(Inches)
Top Ring Land Height
(Inches)
Piston Dome Volume
(cc)
Negative number is dished piston. Positive number is a domed piston.
You Entered:
Bore 4.04 (inches)
Stroke 3.75 (inches)
Rod Length 5.7 (inches)
Cyl. Head Vol. 52 (cc)
Deck Height 0.0 (inches)
Head Gasket Bore 4.060 (inches)
Head Gasket Thickness 0.049 (inches)
Piston to Cyl. Wall Clearance 0.003 (inches)
Top Ring Land Height 0.25 (inches)
Piston Dome Vol. -18 (cc)
Compression Ratio:
10.792 : 1
Bore / Stroke Ratio:
1.077 : 1
Rod / Stroke Ratio:
1.52 : 1
Total volume:
868.345 cc's
Compressed volume:
80.46 cc's
All the answers are within spitting distance of each other, including yours. The common head gaskets have a bore of 4.166 or 4.190, and a compressed thickness of .039" to .041". These minor variations in gasket dimensions won't make any meaningful difference in the compression ratio. I assume you decked the block to attain a good quench. As mentioned, a .049" gasket thickness starts to erode that advantage. Stick with the .039"-.041" compressed thickness gaskets and you'll be better off. A compression ratio of ~10.8:1 isn't too high with aluminum heads and that cam. Remember, too, it will only be less (slightly), depending on the actual head volume.
RACE ON!!!
