optimal dynamic compression
Old Mar 19, 2005 | 12:39 PM
Tomulrich's Avatar
Tomulrich
Default optimal dynamic compression
What would be the recommended dynamic compression ratio for a 427ci .....running on 92 octane pump gas?
How much cranking PSI would the optimal dynamic compression ratio have?
Tom
Old Mar 21, 2005 | 02:23 PM
71coupe's Avatar
71coupe
For a street car, cranking compression should be around 175#.
Old Mar 21, 2005 | 07:46 PM
CFI-EFI's Avatar
CFI-EFI
The number 7.8:1 sticks in my head. Let's see what else pops up.
RACE ON!!!
Old Mar 21, 2005 | 08:54 PM
DOCTOR J's Avatar
DOCTOR J
This site http://cochise.uia.net/pkelley2/
mentions 7.5 - 8.5 for street engines.
I seem to recall Dave Vizzard had some discussion in one to his books.
I'd try the one on SB valve trains. If I run across my copy I'll see if that's right.
HTH
Old Mar 22, 2005 | 01:02 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
A couple of years back I put together a 383 for my '90. Canfield 195 heads, 62 cc chambers, 6" connecting rods, hyper pistons, 11.2:1 static compression. Hydraulic roller cam 224/236, 110icl, 114 lsa, .502" i, .520" e. .041" compressed head gasket. Dynamic compression worked out to be 8.89:1. On 93 unleaded, the car didn't like more than 27 degrees of WOT timing in a 3500 car with 3.33 gears. Had to back out alot of part throttle timing also. I never ran the car with race gas, so I didn't get to see if it was a matter of the heads not wanting the timing or it was octane limited.
The car was crispy and didn't act like you'd expect with that little timing. Timing was verified to the balancer. Ran a best 1/4 mi mph of 118.2.
I think the 8.9 was pushing the limits, probably a little past really. With the larger bore of the 427 I'd go lower.
Old Mar 22, 2005 | 01:24 PM
tapio's Avatar
tapio
Did you measure the cranking pressure?
Old Mar 22, 2005 | 10:48 PM
SloRvette's Avatar
SloRvette
Sorry I didn't. For what it's worth, the cam from that motor is now in a 398 sitting on a stand. Dynamic compression works out to be 9.3:1 now and cranking compression is 205 psi.
Old Mar 25, 2005 | 01:13 AM
comp's Avatar
comp
Hmmmmm more food for thought
To optimal dynamic compression
