4 valve SBC head?
Old Mar 21, 2005 | 08:49 PM
Caboboy's Avatar
Caboboy
Default 4 valve SBC head?
I came across this while I was doing some surfing.........does anybody know anything about them? Some of their numbers are pretty astounding
http://www.araoengineering.com/Chevy/chevysmb.htm
I think I'd look hard at these things if I wasn't married to a smog legal build on this new motor!
Old Mar 21, 2005 | 11:40 PM
korvetkeith's Avatar
korvetkeith
I geuss it's about time for this question again...
Old Mar 22, 2005 | 01:11 AM
cv67's Avatar
cv67
St. Jude Donor '05
Yeah, they're right up the street from me. SBC heads run about 6k/pr.
Old Mar 22, 2005 | 01:12 AM
tapio's Avatar
tapio
http://www.nelsonracingengines.com/videos.html
Check "NRE 32-valve blown 406" video.
Old Mar 22, 2005 | 08:16 AM
chuntington101's Avatar
chuntington101
that 32valve engine is mad!!!!!
be ace if they ran the same heads wit hthte twin turbo set up! andone know how much they would add to the price of an NRE engine????
thanks Chris.
Old Mar 22, 2005 | 09:40 AM
Ramanstud's Avatar
Ramanstud
I've been eyeing the arao heads for a while too. Being the complete package (heads, valves, springs, covers, etc) and having the flow #s that they do- I'll bet the cost really isn't more than 2K over what you would pay for a fully prep'd, ported and assmbled pair of high-end aftermarket heads with less numbers. SO it's big $$$ up front but how much do other people running wild smallblocks put into their cylinder heads?
My only beef is that the company is fairly small and untested. But then again, look at AFR's rep lately and maybe it's not so important.
If I had a little money to play with- I would try them for sure. Now 18* heads are probably comparable, but you have the same issues with exhaust and even more issues with manifolds and compatability.
Old Mar 22, 2005 | 11:02 AM
cv67's Avatar
cv67
St. Jude Donor '05
I have close to 4k in a set of Dart heads, including rockers...
Those araos make killer nimbers with very little cam timing...Only thing i can say is the heads are physically HUGE, and the portwork I saw the day I was there was pretty lousy. Perhaps they can CNC them. Don't know if they would clear/mount accesories.???
Old Mar 22, 2005 | 12:14 PM
comp's Avatar
comp
if i had money to burn
Old Mar 25, 2005 | 12:15 AM
The Green Rocket's Avatar
The Green Rocket
There are plenty of large budget sportsman racers out there - none seem to interested in these particular heads. The Arao/Dominion heads have actually been available for several years now. They would appear to be another one of those totally bitchin looking ideas that fail to deliver horsepower. As I've said in all the other posts on these heads, I get to see them every year at just one show: The L.A. Roadsters Father's day car show at Pomona. It is no accident that they can be found in show car venues rather than in any racing, they are lookers more than performers.
Thomas
Old Mar 25, 2005 | 01:47 AM
gkull's Avatar
gkull
Just look in years passed the people that hopped up ZR1 Vettes. One of the guys on this forum has 4 valve 90 vette. That has bigger than stock valves and cam with a 415-427 ci under neath it and a 200 shot of N2O He was up for the 0-150-0 in the motortread shoot out.
I think he N/A 618 hp at rear wheels. big buck machine with @8000 red line
Old Mar 25, 2005 | 08:28 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Gkull why would the ZR1 only have a 8000rpm redline? I thought the whole idea of having the multiple valves (import cars come to mind) is that the smaller valves have lighter weight so the valve train can be controlled better for high rpm applications while the added valves don't hurt but add to the flow capabilities.
Old Mar 25, 2005 | 09:59 AM
gkull's Avatar
gkull
Mike - It was his ci holding him back. I can't remember what he told me had for a crank. It was either a 3.875 in a 400 block to get 415 ci or it was 4 inch stroker to get 427 ci.
His other rpm limiting point was the ZR1 based injection manifold. Even though it was extensively modified it proved to limit the CFM of air flow in a big ci motor. Same idea of trying to use a ported Super Ram on a big ci motor. Your going to be limiting it to sub 6000 rpm because of limited air flow and how big of a roller cam duration that you can run.
Old Mar 26, 2005 | 03:50 PM
SmokedTires
St. Jude Donor '05
OK, I get it now, Thanks
Old Mar 26, 2005 | 07:13 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
That blown 406ci in the video is one nasty motor, it is unbelievable how fast that thing revs from 1000 to 6000 RPM, take a look at the end the dyno operator gives it a few shots of gas it hits over 6000RPM in about 1/10th of second
Old Mar 28, 2005 | 09:39 AM
VETMANIAC's Avatar
VETMANIAC
I am with the Green Rocket on this one. I saw a set of these flow benched back when they were still called Dominion (I have no idea what, if any changes have been made now that they are Aero). There was also a set of Trick Flow Ford 351 heads that had just had a mild cleanup and flow test. The Trick Flows beat the Aero's across the valve lift range. Back then they were about $5500. Again, I don't know what if anything has changed in their design, but I was unimpressed.
Old Mar 29, 2005 | 12:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
I believe Dominion was the marketing company that used to sell them for Arao. With a little reshaping (they look like huge squared off blocks of aluminum) and some CNC work they might work well. The 2 sets of heads I've seen were hand worked and didn't look good at all IMO
To 4 valve SBC head?
