Gm Zz383
Old Mar 24, 2005 | 08:51 PM
valrico_stingray's Avatar
valrico_stingray
Default Gm Zz383
I thinking about putting this engine in my 64 so I have been doing my homework over in the C2 area. Anybody here using a ZZ383 in any car?
Chuck
Old Apr 1, 2005 | 11:50 PM
rcastor426's Avatar
rcastor426
I bought the HT 383 for my 78, i know it is a little different but it runs ok. only real problem i ran into was that the timing cover was hitting the back of the water pump and would not seal. so i had to take a dremel to the bolds and the back side of the water pump. also the water temp port on driverside head is a different size than stock so i put the stock sending unit into the intake manifold. The ht 383 pulls real strong to 4500rpms, then it is dead... needs more cam. but i have that on the way
