BBlock Cooling System
With A/C off and full coolant system, car cruises at good temps around 170-180 around 50mph. Not much different 10mph faster. However, I was losing about a quart of coolant every 40min of driving. The engine would start to heat up after that,..naturally.
Further inspection revealed the following; In neutral, holding a steady 3500rpm, coolant flows a steady stream out of the expansion hose leaving the cap.
Initially I was thinking poor cap. I didn't pressure test, but replaced with new 16psi cap with no change to overflow problem.
Concerned with sticking (recently replaced) thermostat, I replaced with new failsafe 160temp. This yielded no change.
Additionally, I noticed that with the cap removed and a steady 2500rpm.. (rpm to bring coolant up to cap level) every 10-12 seconds a large splash of coolant blows out and upwards. Concerned I had exhaust gases pressurizing the cooling system via crack/gasket problem, I used a fluid block tester unit.
At idle I showed no color change on the tester unit indicating then that no CO2 was present. I wanted a higher RPM check in case the crack didn't open until then, so I reved her up. However, the littlest RPM increase with the cap removed caused massive coolant overflow. I held the RPM high catching it underneath thinking I'd eventually lose enough to check it with the block tester at higher RPM. I was hoping for a test at 2500rpm. I finally got the coolant low enough including compensating for that 10-12 second big splash. I did a block tester check for CO2 and found no color change at 2500rpm. However, coolant was so low the engine start heating up fast climbing quick towards 250 so I terminated the test.
I am figuring that I've been losing coolant at the expansion area at the cap as I was up-shifting and occasionally exceeding 3500rpm in cruise.
Can I still have an engine crack or head gasket leak that is causing coolant overpressure without showing up on the block tester ?
What else could cause my cooling system to exceed 16psi?
Help????
RACE ON!!!
The cap itself does not leak...its the pressure relief valve. Granted it may be possible for the inner seat where the pressure relief valve on the cap make's contact to not be flat. I'm waiting on a pressure tester to arrive to rule that out.
I neglected to mention that the water pump was NOT stock. Its Edelbrock's Alum pump. I'm hearing that edelbrock's alum pump may put out more PSI than stock requiring a higher PSI system. I've put a question to Edelbrock's tech team and am awaiting a response. I've read in another forum that this pump and maybe Stewart's require PSI cap's around 22psi to prevent overpressuring the stock cap and losing all the coolant.
Any other thoughts???
RACE ON!!!
Perhaps I'm a plain ole dummy, but I fail to see how the pump curve does not increase flow as RPM increases through an unchanged diameter hose size?
Be that as it may I'm still not 100% convinced this is the problem, but if not...my only recourse is to prob to yank the motor as I'm getting fairly frustrated. I didn't build it myself and am not sure what may be going on inside the motor's cooling passages. Plus, I'm not sure if a block tester can be fooled so I might still have a blown gasket or crack that won't show up.
I put in a new chin spoiler, Edelbrock Victor pump, high flow thermostat and a Moroso 19-21psi cap. Now there is no loss of fluid from the expansion tank and the engine runs nice and cool, even in tropics.
Duke
On the subject of the post, I fail to believe that the flow can be so great through a radiator hose, as the restriction to flow, can cause a 16# pressure relief (the cap) to open. And if it some how the hose could cause sufficient restriction (?), the cap is beyond the restriction, where the pressure should have dropped. In short, a better water pump isn't going to cause a radiator cap to bypass coolant.
RACE ON!!
The increased pressure at the pump outlet drops as coolant flows through the system, and the "head" that the pump creates is not large -probably no more than 5 psi at maximum speed. Since the fill cap is always close to the pump suction side, it will not see the pump head.
Duke
slowly improving it for 10 years?
It must have been awful 10 yrs ago
Hint:
i'd do a leakdown test.(bubbles in coolant?)
Duke
RACE ON!!!
cold start it goes up from 1 psi to 7-8 as the revs climb to 2000. it is a linear climb.
cruising hot it is 14 psi. this is not cap pressure(i don't know what the cap/tank runs, but it never overflows w/15#cap)
Whatever the prob is...there is only one source of water escaping...the overflow hose off the expansion tank. Perhaps the tank area has some warpage that is hard to see. I would like this to be the answer. Where Murphy is concerned I doubt this would be my problem, but I haven't ruled that out, as I'm working to obtain pressure test equipment now.
However, for all you fluid dynamic nuts out there, Edelbrock seems to think they may have pressure curves for their pumps somewhere and are attempting to help me out. When the smoke clears I'll post the results here even if it turns out I'm a nut.
"rubber side down"
Hawk
