Pushrod lenght........Can this be right?
Is it possible the shorter pushrods would have caused the pushrod to break?(That's what started this whole saga.)
In your case, your geometry suggests that the rocker to valve stem angle never reaches a perpendicular condition even at max lift. This is evidenced by your max lift condition still pushing the rocker tip outwards. I’m not saying this is wrong, I just don’t know if it’s right. By changing the distance from the rocker stud to the valve stem, you could achieve many different conditions that would track over the valve stem like you described.
Hopefully there is an experienced engine builder out there who may have answers to these questions. I’ve got to believe that pro builders do more than just look how the rocker tip tracks over the valve stem. There are too many other variables that need to be taken into account to get the geometry really nailed down.
That would be "ideal" and may be impossible to achieve with available parts. One frustrating factor, is that the valve stem and valve stud aren't parallel to one another. A longer valve changes everything. I think, as a practical matter, one needs to seek out a combination of parts (read, push rod) that keeps the smallest amount of roller travel, the closest to the center of the valve stem, as possible.
The concept can be difficult to visulize. I hope I stated it in a way that can be understood.
RACE ON!!!
Nice explanation, I understand exactly what you are describing.
I have never seen any of these issues discussed in an engine building book. The height of the valve stem seems like a critical parameter in this mix. Also the fact the rocker stud and the valve stem angle are different makes this a doozy to ever get truly right. (Right being the rocker is perpendicular to the valve at mid lift.)
You bring up another interesting point that the rocker ratio will change depending on the angle the rocker sits to the valve stem. This is also affected on the other side with the push rod to rocker angle.
I've gotta believe the GM guys must have thought about this long and hard. Judging by the lack of detail on this subject, it tends to indicate that all this stuff is not too critical. Set the rocker height to put the average position of the rocker tip on the center of the valve. Though, with all the **** race motor builders out there, I can't believe there isn't some hot rod tweak to get this exactly right.
Yes Pete, my Trick Flow p-rods where off by .005-.010" too - and the advertised size was even stenciled on the p-rod (but wrong).
Anyways i gave up trying the adjustable p-rod for a tool with the block in the car.
Used the checker tool from ProForm and Moroso (yes both) - much easier and the rocker tip travel (using new p-rod length) looked good by eyeball calibration. Moneypit if ur still worryed u could double check with one of these tools.
But that #1 (exh) rocker looks good from the pix.Good luck and report how that new Isky solid cam works out.
