ram jet 350 ???
Old May 15, 2005 | 10:27 PM
Glenn's 67 BB Vert's Avatar
Glenn's 67 BB Vert
Default ram jet 350 ???
Am thinking of putting in the ram jet 350 engine in the 66 coupe i just bought - -what do you think of this engine??? thanks - -Glenn
Old May 17, 2005 | 08:10 AM
cbernhardt's Avatar
cbernhardt
C1 of Year Finalist (track prepared) 2019
Glenn:
I have a Ram Jet 350 in a '62 frame conversion car (C4 suspension). (www.carols62.com)
The installation is pretty straightforward. You have to supply a high pressure fuel pump, supply line and return line. One "problem" with the Ram Jet is that the top of the air plenum is about 9.75" above the "china wall" (flat section) on the block. A friend of mine has a Ram Jet intake in a '64 and he had to use a big block hood in order to clear the manifold.
The original Ram Jets (like mine) did not have O2 sensors and they run very rich. The newer versions do have O2 sensors and hopefully that cured the richness problem.
I have had my engine running for about 3 years and almost 17,000 miles and so far it has been trouble free. The engine has good power and plenty of torque. I have a T-56 6 speed hooked to mine and, although I have never actually timed it, it feels quicker than my C5, at least up to about 100 mph.
If you have any specific questions, let me know.
Charles
