will a 3.875 stroke fit?
If your stock cam is in the .930 or less, it's considered a small base circle cam and clearance is not a problem. But you have to check everything!
I have a 4 inch stroker crank with 350 chevy size mains with big H beam 6 inch rods.
Stay away from Comp Cams
Crane cams and other vendors sell off the self small base circle cams.
I can't say enough about stay away from comp cams. The morons will lie to you every time
RACE ON!!!
I went to an race engine shop about 2 months ago. They had entered the national small block max hp contest last year and got the 4th in the nation. The winning motor had AFR 227cc heads done up by their very talented head design person. They were going back for the big block contest this summer.
Kidd performance in Twin Falls Idaho
I'm not ******* anyones accomplishments, 733hp is certainly impressive. But due to the shear number of SBCs people build, it would be nearly impossible to know for sure that yours is the king on pump gas.
Everything down to the thin oil. I was at "kidd performance" in twin falls an the did 100's of dyno runs just to get the the best. I wish that they had done the final adjustmets on my 383 or 427 SBC's
I didn't mention his name before because Hot rod said his name. It's Tony Mamo I hope I got the last name spelling right. Tony and the team at AFR is coming out with a new line of great AFR heads that out flow any in the past.
I didn't mention his name before because Hot rod said his name. It's Tony Malmo I hope I got the last name spelling right. Tony and the team at AFR is coming out with a new line of great AFR heads that out flow any in the past.
P.S. I'd like to give an example here. We just delivered 2 engines, identical short blocks, (BB's on pump gas), the first had 741HP/662 Ft.Lbs. (375CFM @.700" thru a 360cc int. runner), the other, 732HP/706 Ft.Lbs. (375CFM @ .700" thru a 320cc int. runner). You can see by the torque that not only the CFM is important, but due to the "smaller" runner, the second engine is much more powerful. There would be no comparison in a "heads-up" race with all things being equal, due to the torque difference. The next time you ask about CFM numbers (from the mfr's.), be sure to ask "what size bore were they tested on"? You may be surprised by the answer.
"couple" of CFM difference from a 4.030" and a 4.155". Using 3 flow-benches over here I can tell you that you'll see more than a "couple" CFM, maybe more like about 25 or better. Thanks, Gary in N.Y.
