Need input about these cam spec's
Old Jun 13, 2005 | 05:16 PM
V's Vette's Avatar
V's Vette
Default Need input about these cam spec's
I'm going to begin rebuilding my '89's engine next week. At this point I'm looking at the following cam from Comp Cams. I have to be careful in this build since I live in Calif and have to pass smog. So...what do you think of this:
Xtreme Energy - Computer Controlled
"Good for TPI 305 or 350 with aftermarket chip and upgraded exhaust. RPM's 1500 to 5500
p/n 08-502-8 269 276 218 224 .495 .503 112°"
Any and all input appreciated!
Old Jun 13, 2005 | 06:21 PM
Pete K's Avatar
Pete K
It is a hair bigger than what I usually put in an l-98 350. Should work out ok though.
Old Jun 14, 2005 | 09:19 PM
V's Vette's Avatar
V's Vette
ttt
Old Jun 14, 2005 | 11:59 PM
Caboboy's Avatar
Caboboy
224* of exhaust on a 112 will give you a bit of an idle Vance.......especially with 350CID +/-. You'd really need to be on top of it for smog compliance I'd think. Take a look at page 146. There's a couple nice cams on a 114 that should idle a lot better with a more spirited stock build
Old Jun 15, 2005 | 10:30 AM
V's Vette's Avatar
V's Vette
Tim,
The reason I went with the one mentioned was due to a conversation w/Alvin at pcmforless. He said that if I went with the one on p.46 listed as 08-304-8 (210/220) I'd probably be "disappointed" and that the exhaust should stay below 228 and ideally 225. He felt that he could definately tune me smog-safe with a cam that was a 218/224 and LSA 112.
What do you think?
Old Jun 15, 2005 | 06:51 PM
Caboboy's Avatar
Caboboy
I think I'd go with Alvin's recommendation in a heartbeat! My only concern would've been a tighter LSA combined with that duration. Go with Alvin man, he's had a lot of success on this forum! Keep me posted, and watch those knuckles!
Old Jun 15, 2005 | 08:39 PM
V's Vette's Avatar
V's Vette
Ah, and here I'd forgotten how scraped up I get when I work on the car! Just part of the fun, I guess.
Old Jun 20, 2005 | 04:08 PM
elkabong's Avatar
elkabong
I put that cam in my 84 crossfire 383. I like it a lot. Very streetable. The 112 lsa has worked out fine. AZ has similar smog laws as Cal.
Old Jun 20, 2005 | 06:49 PM
V's Vette's Avatar
V's Vette
WoW! Just the kind of feedback I needed for confidence...Thanks!!!
To Need input about these cam spec's
