No A/C more HP ???
Old Jun 29, 2005 | 08:50 PM
BIGBYRD1993's Avatar
BIGBYRD1993
Cruise-In XI, XII Veteran
NCM Lifetime Member & Ambassador
Default No A/C more HP ???
If I disconnect the A/C Belt , would there be a gain of Horsepower??
Old Jun 29, 2005 | 08:55 PM
tmjvett2009's Avatar
tmjvett2009
St. Jude Donor '09-'10-'11
More then likely not enough to worry about
Old Jun 29, 2005 | 10:35 PM
BIGBYRD1993
Old Jun 29, 2005 | 11:22 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
If the compressor's not engaged, you're only spinning a pulley.
Old Jul 1, 2005 | 07:17 PM
SHINOBI-X's Avatar
SHINOBI-X
My car is an 84'.
its not worth the gain IF your A/C is working! i took all mine off except the condensor in the front of the radiator because it was junk and had multiple leaks and corrosion. i ditched it and dropped 40 pounds of weight. thats the real only advantage i've seen.
Old Jul 2, 2005 | 05:49 PM
BIGBYRD1993
Thanks, I guess I'll leave it alone...
To No A/C more HP ???
