Hydraulic vs Mechanical Roller
THanks,
Doug
Thanks,
Doug
What size are you thinking of going, out of curiosity?
The disadvantage to the mechnical roller is that higher spring rates are required because of the faster lifter/valve action. The higher spring rates are harder on the rest of the valve train, especially the lifters and valve stems and guides. Racing cams are not recommended for the street because of the longer times street engines spend idling or running at low speeds. This is hard on the roller lifter because the roller will overheat because of the high spring pressure. At higher engine speeds there is more oil splashed on the cam and lifters which helps cool the roller. Lifter manufacturers have begun doing things like putting grooves in the lifter body to channel oil to the roller to cool it (cool being a relative term here).
There are mechanical rollers designed for street use though that still have the advantage of faster ramp rates over hydraulics (but not as fast a ramp rate as a racing lobe), and therefore don't require as much spring pressure as a racing cam.
I'm running a Comp Cams Extreme Energy street solid roller with the recommended springs (~150 lbs seat pressure). I've got about 15,000 miles my setup, and the valve train holds adjustment very well. I run through them every time I change the oil (~3000 miles) and have to tweak a couple, and that's about it.
Hope that helps,
Dan
Good post on the benefits/tradeoffs of mechanical vs hydraulic rollers. Whose lifters do you use with your cam?
Thanks,
Doug
A mild s-roller with good oil pressure and correct springs might last 50K + miles in a sub 7000 rpm motor.
The use of stud girdles and allen locking rocker nuts makes adjustment more of a check
Dan
Isn't there a less sensitive knock sensor/ I thought some guys use the Z06 one. I'd like to hear more about this
Good thread, btw!
"You can actually hear Rhoads Lifters work! They have a sound all their own; a “mild ticking” sound at idle which tells you they're working"
"our competitor's ads that imply Rhoads Lifters are in some way unsafe for your engine because they tick"
"Rhoads Lifters are totally compatible with all hydraulic cams including today's modern state-of-the-are fast acting computer profiles. Performance cams benefit the most, but you can boost low-end torque by up to 15 hp with a stock 350 Chevy cam! Note: Rhoads Roller Lifters will be available soon. Check this website for further information."
I agree with the idea that a flat tappet will give more area under the curve, but I also think I like the idea of a roller as opposed to metal on metal like a flat tappet. Correct me if I am wrong here, but won't there be wear issues with a flat tappet as opposed to a roller lifter?
If the lifter noise is audible though, that could very well set off a knock sensor I think, and that would not be very cool. Is there a way to damp or filter the ticking? Does the knock sensor output a true DC voltage, or is it AC? Not sure what the frequency of "ticking" is as opposed to knock, but a notch filter on the knock circuit may work if the output is a reactive one, and as long as you are well above the half power point in the pass freqs, probably require a very sharp rolloff too though.
So in terms of efficiency and durability the hydraulic roller wins out. Seems to also be the best bet for a driver/street warrior. I know this, if I keep my Superram on, solid rollers are out as I have to pull the whole friggin intake to get the valve covers off.
The solid roller for all out performance/high rpms?
Man, You guys are awesome, I learn so much on here and I appreciate all of you sharing your knowledge so freely!!!
Doug
I think you can have a little more vacuum, a slighly better idle and can get a bit more duration at .050 for the same overlap as a hydro with a street solid roller. The drawback is extra maintenance and maybe a bit less longevity. It's all about what you like.
Rhoads lifers are another personal preference thing. I've used them in the past and wouldn't use them again.
