406 running hot
Old Jul 19, 2005 | 09:53 PM
brimcc's Avatar
brimcc
Default 406 running hot
This is my first post, I need advice. Last year I put a 406 in my 79. Problem is it runs hot, around 220. I had the rad record. I have a stock water pump on the engine. Also, the heads have been drilled out. Any ideas?
Old Jul 19, 2005 | 11:43 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Aluminum rad and electric fans, mine never goes above 190 degs.
Old Jul 20, 2005 | 02:07 PM
The Money Pit's Avatar
The Money Pit
Old Jul 20, 2005 | 02:39 PM
Frankenvette 63's Avatar
Frankenvette 63
Is your sensor on the heads or the intake? My 406 (66 Nova) ran 210* - 230* on the head (Dart II aluminum) and I never worried about it. It had an aluminum radiator, dual electric fans and an electric water pump.
Old Jul 20, 2005 | 09:59 PM
Ironcross's Avatar
Ironcross
I run a 180 thermostat with a factory stock cooling system in a 1970 LT1 370Hp an it never gets above 170 in all situations.
Old Jul 21, 2005 | 10:04 AM
CFI-EFI's Avatar
CFI-EFI
Either you've never let it warm up or your thermostat is stuck open. Never over 170° with a 180° stat??? It shouldn't run less than about 180°.
RACE ON!!!
Old Jul 21, 2005 | 12:16 PM
Ironcross's Avatar
Ironcross
RACE ON!!!
If it was stuck open it would BOIL.
To 406 running hot
