396 engine...chime in please!!!
Old Jul 25, 2005 | 01:46 AM
corvette90-1's Avatar
corvette90-1
Default 396 engine...chime in please!!!
hy all..
im building a 396 for my 90 6 speed
what would you say to following:
396, based on a GMPP block, new ( and already at home)
Accel Single plane EFI Intake
210cc AFR Competition heads
plenum in "Jeb" style
Cam with about 236/240 .600 lift (not 100 %sure, but around this)
i run the combo through Destop dyno and yield very good streetable results, with lots of torque, also down low
i would prefer 195cc AFR heads, Comp.port, but the only support lift to .550....
also, want to go with a hydraulic roller cam....!!!! is 220lbs seat pressure to much for a hydraulic roller? (thats the springs, that come with the AFR 210´s)
maybe i should refer the book "How to build big inch chevy small block"
theres an 383 street motor, that build 480hp, with a mild cam and single plane efi......and AFR 210´s.........so i think they should be a good match for a 396...but again...
any Input would be nice
best regards
Old Jul 25, 2005 | 02:16 AM
cv67's Avatar
cv67
St. Jude Donor '05
I'm no expert, but that sounds kind of high. I'm running 200/500 on a solid roller (250/254@.050, .660/.670 lift). It's been pounded into my thick skull that you want the least amount of spring pressure yet not have the valves float.
Old Jul 25, 2005 | 07:33 PM
Simmo's Avatar
Simmo
Id use the 195 heads with that much duration especiqally as you are mentioning low down torque. Dont expect a computer program to be accurate measuring low rpm torque on this sort of set up. 220lbs on the seat is too much pressure on a hyd roller cam, infact from what Ive seen hyd roller cams dont need a lot more pressure than a hyd flat tappet cam.
My 238 BBC hyd roller came recommended with as little as 120/300, though Im running a tad more. Another builder on this site running hyd roller cams with .720 lift used 160/380lbs
Springs are cheap, get the right ones.
Old Jul 26, 2005 | 09:57 AM
gkull's Avatar
gkull
AFR has 4-5 kinds of springs for each head. It just depends on what kind of cam your running.
396 motors are so much better than a 383. Crane makes a nice HR cam small BC of 232/238 112lc Then just use 1.65 or 1.7 rockers to get it up into the .600 lift.
Crower made my steel 1.65's and I should have just bought the 1.7's
210 cc is a minimum on performance heads. Since your going single plane and EFI. The 227 cc is the better choice
To 396 engine...chime in please!!!
