Air flow question
Old Sep 10, 2005 | 01:42 AM
Performance nut's Avatar
Performance nut
Default Air flow question
I been trying to make sense of a couple of things.
I have posted several questions about an L98 engine build that will pass California emissions. I already have a set of AFR 195cc heads with competition porting. Recommendations have been a Superram, Lingenfelter 74219 camshaft (219/219 duration @ .050 .560"/.560" with 1.6 rocker), and a 383. Ok, sounds good.
After looking at all the airflows of everything, I have one question: what is the "choke point" for this engine? Does increasing airflow in any of these components really going to improve performance or is the engine going to get all it needs?
The reason I ask is that I think that my heads are too much for the engine. Even with an extrude honed Superram, one site shows each runner capable of flowing 240cfm, which is what the heads flow at 0.4". I understand that just because the cam lifts 0.56" doesnt mean 280cfm will be flowing through the intake valves.
My goal is to build this engine once and be done with it and not have to play with it trying to tweek it. Thanks for your input.
Old Sep 10, 2005 | 07:50 AM
silver84's Avatar
silver84
are there some people on this forum that think
that flow numbers should 'match'?
if so, what would you rather have?
1} three components,
...300 cfm@1 psi, 300cfm@1psi, 300cfm@1psi,
2}different three components,
...300cfm@1psi, 300cfm@0.5psi, 300cfm@0.7psi
? one system flows 300cfm@3psi, the other
flows 300cfm @2.2psi ???
Old Sep 10, 2005 | 08:25 AM
SWCDuke's Avatar
SWCDuke
As far as whether the components are properly matched, spend a hundred bucks to buy the Engine Analyzer program and run simulations to your heart's content.
When the Mach index gets up to about 0.55 the inlet system is essentially choked, and the engine won't make any more power or revs unless you have higher flowing components.
Anything else is just guessing!
Duke
Old Sep 10, 2005 | 09:39 AM
Caboboy's Avatar
Caboboy
I have this exact same setup on a 421CID. My Superram was hand ported and flows 280 on the bench. Extrude hone claims they can get me 290+ but I don't need that (it was gonna be $650). My heads flow 286 @ .500 and 292 @ .600 with a cam lift of .560, so as you can see, your parts are well matched.
My build is EO compliant here in California, and just recently dyno'd at 504 torque at the wheels...............you're on the right track with your build!
Old Sep 10, 2005 | 08:21 PM
Performance nut
Wow, 421. I assume that is an aftermarket block? Those flow numbers are excellent not to mention the power.
If you dont mind me asking, what cam are you using and what were your last smog numbers?
Old Sep 12, 2005 | 11:18 AM
Caboboy's Avatar
Caboboy
Same cam as you plan.....in fact the whole setup is the same (see sig). It's a factory 400 block bored .030 over and stroked to 3.875....... I don't recall the exact smog numbers, but I do recall it was clean as a whistle
Old Sep 12, 2005 | 05:08 PM
gkull's Avatar
gkull
So does that mean that you got the chip all figured out?
Old Sep 12, 2005 | 06:13 PM
Caboboy's Avatar
Caboboy
It does George...........man, I'm a happy camper!
Old Sep 24, 2005 | 05:05 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default U want numbers? Ok try these.
Lets look at airflow per cylinder:
For a 383ci mtr @ 6500rpm thats only 48ci/cyl with only 3250 (6500rpm/2) intake strokes per min.
And with 1 ft3 = 1728ci we have (48ci/1728)x3250strokes/min = 90cfm each cyl (or 720cfm entire eng @6500rpm).
Well with a optomistic volumetric effecency of .9 produces a flow of only 81 cfm each cyl.
So this kinda throws out those 240ish cfm flow numbers as a realistic number (man sometime i out figure and surprise myself ).
I see u posted u understand thats not what really flowing through the head. But for comparision thats what the head can flow. Its just a guide line for comparision and can be helpful.
And really what we all want is low restriction with high flow numbers with maintaining good port velocity at low flows. What i'm saying is a head that flows 240cfm @ .5" lift with a small runner (180cc) would be my choise over a head that flows same but has a larger runner (195cc). No way it will ever get to see 240cfm without supercharging.
Choke point is the vlv from what i've read but everything between the vlv and atmosphere that adds restriction will reduces flow and power. That why sometimes even the air filter can be the power thief.
Look at each part to reduce restrictions and do the best u can with ur own buget.
Good luck. cardo0
To Air flow question
