From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The torque curve is a result of all the parts working together and displacememt has a lot to do with it
That said I do not know the exact theory as to why the solid roller helps flatten out the torque curve like it does but I do know that I would not get the same result of the torque only changing about 40ft/lbs from 2000RPM to 5000RPM and probably 6000RPM froma any other type of cam.
I have an idea it is partially a result of being able to obtain a much higher lift while keeping the duration relatively low due to the aggressive ramps.
Here are the specs on the cam :
And here's a pic of really cool Chevelle just for fun
All my cams were .050 timing. Your cam of 101 lsa ???????????? real radical race motors might get down to 106 and have 2000 rpm idle because of so much overlap.
I went back and looked at that dyno sheet you posted. 454 hp and 411 TQ
Let me get this straight - your doing that with a LPE 213 cam which is 213 intake duration .050 You need to input the cam event numbers to get closer to true results on these desk top dyno programs. Seat to seat numbers really don't mean much. .050 lift numbers are much better.
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Since the intake and exhaust lobes on a SBC are on the same camshaft, there's only so much you can do...save the lifters.
'bleed down' lifters have been around for a while. At low rpm they bleed off both lift and timing, and higher rpm they let the full range of the camshaft is seen by the valves.
On the new Impala, the pushrod V6 has variable timing, so it's coming.
